94 Transmission into an 82, differences, changes needed? - Mustang Evolution
Old 09-09-2012, 06:24 PM   #1
i am going to put a t5 out of an 94 gt and put it in my 82gt i just want to double check with what i heard and make sure that i dont need to change bell housings and or drive shafts i took out the 3 speed with overdrive
82stang30 is offline   Reply With Quote
Old 09-09-2012, 08:21 PM   #2
Re: trans
I don't know that for sure.
You will have to check the mounting bolt pattern, the length and driveshaft connection type, the length, size and tooth count of the input shaft and the hole size in the bell housing to see if it will fit.
Old 09-09-2012, 08:29 PM   #3
aegischief's Avatar
You will need to use the bell housing from the 94 since the input shaft is a little longer than the old T4. The driveshaft will work fine.
aegischief is offline   Reply With Quote
Old 09-09-2012, 08:53 PM   #4
Okk thanks for the info its hugely helpful
Old 09-17-2012, 03:28 PM   #5
So by the way in case this comes up again the trans will bolt up i needed the bell housing from the 94 but i also had to go get a 94 starter because they are different from the 82 to the 94 also i am going to Need to find a h pipe for a 94 and rework the exhaust cuz the 82 y pipe hits the fork that holds the throw out bearing
Old 09-17-2012, 09:59 PM   #6
Blown347's Avatar
Re: trans
Yea going from the sn-95 to the fox parts can be tricky because everything got confined starting in 94. But an H-pipe is way better anyway
Blown347 is offline   Reply With Quote
Old 09-18-2012, 07:09 AM   #7
I could be wrong, but wouldn't just get an h pipe for a fox? The only thing different in a fox and sn95 bell housing is the sn95 bell is 5/8" bigger. I can see the y pipe not working, but I bet a fox h would.
P.s. This is just my assumption, I dont experience with this swap.
Old 09-18-2012, 07:17 AM   #8
deadsp0t's Avatar
Use a Fox H-Pipe. I've read that the socket end that bolts to the headers is different on 94-95.. Believe the 94-95 may be larger which may not be an issue, but then again it might. Using fox parts would be best. Also use the 94-95 bell to avoid fittment issues, as stated above the input shaft is longer.
That's unimpressive
Old 09-18-2012, 08:17 AM   #9
I did use the 94 bell bolt pattern of trans for t5 from the 4 speed are different at thus point im going to need the fox double hump cross member and the fox h pipe apparently 82 didnt use an h pipe like they did on the newer foxes
2000 Ford Mustang, could my transmission blew? JackNJ Pre-2005 V6 Mustang 3 09-09-2012 08:13 PM
87 AOD rebuild bcosta56 1979-1995 Mustang GT 15 03-04-2012 09:47 AM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
01:35 PM
