leaking a little oil from rear - Mustang Evolution
Old 09-10-2012, 06:14 PM   #1
93_347foxbody's Avatar
my car is leaking a little oil where the drive shaft goes into the rear. i was told a yoke seal but i tired finding one on summit and either its under a different name or something. is there another name for it, or is it something completely different?
93_347foxbody is offline   Reply With Quote
Old 09-10-2012, 06:23 PM   #2
Filibuster
Pinion seal..there only a few $$
XXSTEVEO66 is offline   Reply With Quote
Old 09-10-2012, 06:54 PM   #3
Alright thank you
Old 09-10-2012, 08:30 PM   #4
Re: leaking a little oil from rear
You'll also need a new pinion nut and a Chiltons manual to do it right. Otherwise you stand a good chance of destroying the rear end if you over tighten or under tighten the pinion nut.
Old 09-11-2012, 07:31 PM   #5
i got a manual and im gonna pick up everything i need tomorrow, im guessing this problem came about because of my rear shifting a while ago? also i was leaking oil from the differential cover, and a little up near my tranny, its not tranny fluid though i think because its not a reddish color. would anything else inside my rear be damaged from the shifting? and how could i tell? i never had a rear apart before so im not sure what to look for.
oh and also is my driveshaft supposed to be able to turn back and fourth a little bit or is some bushings or something damaged?
Old 09-11-2012, 07:39 PM   #6
when you take the cover off, if anything major is wrong you should be ble to tell by looking. look for metal flakes in the oil. and check wear on the gears if the teeth on the gears are getting round, sharp, or chipped then they ars damaged.
yes the driveshaft will move a "little bit" back and forth.
Old 09-11-2012, 08:06 PM   #7
Alright. Any clue what the oil up near the tranny would be from?
Old 09-11-2012, 08:46 PM   #8
If your car is a 5-speed it may use oil instead of fluid.
Or, what you are seeing could be a bit of oil out of the grease in the u-joint.
01:12 AM
