oil leak - Mustang Evolution
Old 03-25-2008, 06:56 PM   #1
oil leak
my 95 gt is sitting in my garage as i wait for parts for it to come i noticed its leaking oil from around the oil pan area has anyone ever had a leak in that area or have an idea where it might be coming from
95blackgt is offline   Reply With Quote
Old 03-25-2008, 06:57 PM   #2
Re: oil leak
If it's not from the oil pan itself next best bet is rear main seal
Old 03-25-2008, 07:05 PM   #3
Re: oil leak
ya i was kinda thinking it might be the rear main seal...has anyone ever had that replaced if so what does it run to fix it
Old 03-25-2008, 08:07 PM   #4
Re: oil leak
I replaced mine when I put the new engine in, so I don't know how much it'd cost to do it with everything in tact.
Old 03-25-2008, 08:15 PM   #5
MonteCitan's Avatar
Re: oil leak
It's notorious on the 5.0s, rear main.. typically even freshly replaced ones leak within a few miles
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-26-2008, 10:35 AM   #6
Scut95's Avatar
Re: oil leak
Its not a fun job to do yourself....you need to drop the oil pan, which requires you to drop the k-member....that also means you must support the engine some how....mine leaks too but i just deal with it because its such a pain to change out.
Old 04-03-2008, 09:53 PM   #7
silverstangboy's Avatar
Re: oil leak
I really just depends on how much is leaking... 5.0's are bad to leak around the oil pan seals as well, front and rear main seals leaking can also be a sign of bad things to come.
93 mustang notch
~450hp 331 stroker - Sold
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Exhaust Leak Help 97_GT 1996-2004 Mustang GT 8 05-20-2007 11:49 AM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 08:40 PM
3F3Furious leak Thomas91169 The Bar 22 11-09-2005 07:53 AM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
12:23 PM
