NEED HELP PLEASE, idle probs 95 stang - Mustang Evolution
Old 09-12-2012, 09:35 AM   #1
Exclamation NEED HELP PLEASE, idle probs 95 stang
Im looking at buying a 1995 mustang with a 5.0. The owner says he thinks it has a lower intake leak... But it sucks when u put ur hand on the valve cover opening. Idk if its the IAC i didnt check it. My father who is pretty good with engines wasnt sure if it was a stuck valve or maybe even a head gasket... I dont understand why its sucking air in help please i want this car and hope its something simple!
2stangkruser is offline   Reply With Quote
Old 09-12-2012, 12:15 PM   #2
Jeff44's Avatar
Check all your vacuum hoses and make sure all your fittings are tight. You have a vacuum leak coming from somewhere.
Jeff44 is offline   Reply With Quote
Old 09-12-2012, 02:40 PM   #3
Spray some starting fluid or carb cleaner around suspected areas carefully. If your motor isles up when spraying an area, then that's the problem spot.
02:30 AM
