Smog elimination - Mustang Evolution
Old 09-12-2012, 01:04 PM   #1
91notchback's Avatar
Smog elimination
Ok guys. I've got the egr block off plate and the MIL eliminator for doing this. I don't live in an emissions county so I'm good there. The reason I'm doing it is, all the vac lines were trash anyway. The charcoal filter isn't hooked either. What all can I eliminate? Anything that's hooked to intake vaccum?
---------- Post added at 02:04 PM ---------- Previous post was at 01:45 PM ----------
I will take pics of my question areas when my phone charges if that will be of any help.
91notchback is offline   Reply With Quote
Old 09-12-2012, 04:35 PM   #2
The pump, egr, plug the holes in the heads. And plug the tube that runs to the down pipe.
I removed my charcoal canister. But many dont lime to cause you will have extra fumes.
The heads can be plugged with a short 5/8 11 bolt.
For the down pipe you can cut the tube about 1/2" away. Then crease it and weld it closed. Or find something to cram in it that will stay good.
If you need a belt diagram let me know. And that's about all I got. Haha.
Old 09-12-2012, 05:17 PM   #3
There were two of these. (looked like proprtioning valves or something to me.) That's where most of vac lines were bad. I've been fighting rich conditions. I'm still hunting, but I think this might explain it!
Old 09-12-2012, 05:29 PM   #4
egr silinoid? idk. its hard saying because my motor hasnt had anything stock on it for years.
Old 09-12-2012, 05:50 PM   #5
Lol! I understand man. I've just been fighting rich forever! My dad always says to keep it simple. I I just figured I'd hawk the dead vac lines, and try to sort it all out.
Old 09-12-2012, 06:19 PM   #6
Maybe someone that has one of those dikamabobs can let us know what heck it is. Haha.
Old 09-12-2012, 06:22 PM   #7
I've been going through all my useless vacuum and wire lines and I don't recognize that.
JayKranz is offline   Reply With Quote
Old 09-12-2012, 06:32 PM   #8
watson 1025's Avatar
I have a 3.8 (for now) so idk wat this is worth but I had 2 airpump sylinoids and an egr sylinoid that looked just like that. I deleted all emissions so I unplugged em, tossed em n my garage and its ran fine.
watson 1025 is offline   Reply With Quote
Old 09-13-2012, 05:07 AM   #9
There were two on mine also. I do believe that was the info I was looking for. Thanks man!
Old 09-13-2012, 07:22 AM   #10
Not a problem man! I did hav a 4th one that went to a sensor on my intake but I'm almost positive the 5.o doesn't hav that.
Old 09-26-2012, 11:38 AM   #11
Anybody know what size bolt to plug the exhaust cross over holes in the back of the head with?
---------- Post added at 12:38 PM ---------- Previous post was at 12:35 PM ----------
I was told 5/8-11 but it dosent seem like its the right threads per inch. Diameter is right but thread lead dosent want to line up.
Old 09-26-2012, 11:43 AM   #12
That is the correct size or you can get a thermactor plug from Napa
Old 09-26-2012, 11:50 AM   #13
Ok. Must not be holding my tongue just right. Just wanted to make sure before I kept on trying. Thanks man!
Old 09-26-2012, 12:01 PM   #14
Those threads are usually carboned up. If you can work a small round wire brush or something in there to clean them up it will help.
Old 09-26-2012, 12:10 PM   #15
That's what I was just thinking. I got the bolts from the machine shop I work at, and I was starting to doubt our tooling and machine maintenance stockers...lol!
Old 09-26-2012, 12:11 PM   #16
If you are unsure the thread count is correct, you can count the threads. There should be 11 threads per inch.
Old 09-26-2012, 12:20 PM   #17
TH
I dont have to worry about broken brush bristles or gunk getting into the heads?
Old 09-26-2012, 12:42 PM   #18
Forum Car Trader
90GTNovi2000's Avatar
Vacuum!!
90GTNovi2000 is offline   Reply With Quote
Old 09-26-2012, 01:09 PM   #19
Haha! Don't I feel like a smart one... thanks 2000!!
Old 09-26-2012, 07:58 PM   #20
TH
Originally Posted by 90GTNovi2000 View Post
Vacuum!!
That or just start and rev it a bit to blow out the gunk.
04:22 AM
