Where can I find a MAF harness? - Page 2 - Mustang Evolution
Old 09-20-2012, 04:27 PM   #36
91notchback's Avatar
Let me know when you pick one up and I will walk you through it with reference pics of me checking mine if you need it.
91notchback is offline   Reply With Quote
Old 09-20-2012, 04:59 PM   #37
Moyhuerta's Avatar
Dis is how high my rpm is nd it dosnt go down at all
Moyhuerta is offline   Reply With Quote
Old 09-20-2012, 05:05 PM   #38
Hard on tranny and rear end going into gear. Especially if it's an auto...:eek
If you want to do it yourself and stay away from pricey shops, it would be worth it to buy some tools to check things with. You will always have them the next time you need them.
Old 09-20-2012, 05:08 PM   #39
Moyhuerta's Avatar
But the weired thing is if I disconnect a pigtail dat connects to the MAF it goes bakk to 1000 rpm
Old 09-20-2012, 05:10 PM   #40
New info...alright! There is also a write up in the stickies section about checking your MAF. You will need the multimeter for this also.
Old 09-20-2012, 05:10 PM   #41
did you clean your maf? when you unplug certain sensors, it will send the ecu into an "open loop" which is basically a fixed set of parameters. this is because the ecu doesnt know what to do with out the sensor not giving it information. so that is normal, but is not your fix.
Old 09-20-2012, 05:12 PM   #42
Moyhuerta's Avatar
Cuz I bought a new MAF but I used the same harnest wires from the old one
Old 09-20-2012, 05:15 PM   #43
I did not know that but it makes good sense. Basically the ecu is stuck on some kind of repeat without being told what to do.
---------- Post added at 06:15 PM ---------- Previous post was at 06:13 PM ----------
New sensor or MAF "tube"? If its the actual "tube": What size MAF? Calibrated for what size injectors? What size throttle body are you using?
Old 09-20-2012, 05:16 PM   #44
Moyhuerta's Avatar
So wat do I have to do reset it or wat cuz idk wat to do anymore
---------- Post added at 03:16 PM ---------- Previous post was at 03:15 PM ----------
Everything is stock nothing is upgrade just the cold air intake
Old 09-20-2012, 05:21 PM   #45
Sorry if I repeat myself any. Just trying to gather info. You said the MAF was new. Sensor or housing? Why did you change it? Any trouble with wiring harness before the change? The sensors are very vulnerable to damage. (I believe the wires are (platinum?)
Old 09-20-2012, 05:23 PM   #46
yes. but its not good to run like this. because the ecu is unable to adjust properly which will cause inacurate a/f mixtures.
Old 09-20-2012, 05:30 PM   #47
I understand this completely. With the little info I can put together, it sounds to me as if the sensor might have been damaged. I have read that it is easy to damage one. I was VERY careful while cleaning mine. But the issue seems kind of up in the air at this point...
Old 09-21-2012, 05:57 AM   #48
Dion11197's Avatar
I agree, sounds like a bad MAF. Since the idle is steady and not surging we can rule out IAC valve, the idle is consistently high but drops when you unplug the MAF, so that pretty much rules out a vacuum leak. I would still check and set the TPS voltage, and the MAF first which both require a voltage meter. That'll help you pin point the problem, but sounds like a bad MAF.
Dion11197 is offline   Reply With Quote
Old 09-21-2012, 08:09 AM   #49
93slowstang's Avatar
For reference the idle will more than likely drop if he unplugs the iac or tps as well. My idle has done this before even after resetting it and it turned out to be the iac which was only a couple months old.
Old 09-21-2012, 12:39 PM   #50
Dion11197's Avatar
Good to know! I can only speak on what I've seen or experienced. That sucks though, whered you get the part from?
Old 09-21-2012, 02:31 PM   #51
The one that went bad was an autozone unit, the one on it now is a ford motors part.
Old 09-22-2012, 10:36 AM   #52
Dion11197's Avatar
Wow, and the FMS unit is probably twice as much, haha! I need to replace the one on my 86 GT. so this is good info.
Old 10-08-2012, 07:11 PM   #53
Moyhuerta's Avatar
I sold my problem guys on my car i had to by a new iac
Old 10-08-2012, 08:43 PM   #54
Good to hear.
Old 10-08-2012, 10:08 PM   #55
Moyhuerta's Avatar
Now their is another problem i tested my car today on the highway nd on first gear it only goes up to 5000rpm wen befor i used to redline it is dat good or bad
Old 10-08-2012, 10:32 PM   #56
Doesn't really sound like a good thing.
Old 10-08-2012, 10:41 PM   #57
Moyhuerta's Avatar
So its bad dat it dosnt go further then 5000rpm???
Old 10-09-2012, 12:12 AM   #58
WhiteCobra94's Avatar
Could it be the Injectors maxing out?
Old 10-09-2012, 12:33 AM   #59
Could be, I've been trying to find a solid answer online. Only thing I can think is the PCM isn't getting the correct signal to shift.
Old 10-09-2012, 12:38 AM   #60
I only reason I say that is when I did my motor swap , I had it dyno tuned and the first 2 pulls my injectors we're maxing out and the power band dropped at 5,000rpms
Old 10-09-2012, 02:43 AM   #61
But your motor isn't stock either, his is.
Old 10-09-2012, 10:01 AM   #62
I know that , he could have bad injector/s, that could do that same thing !
Old 10-09-2012, 03:43 PM   #63
Moyhuerta's Avatar
So wat should i do???
Old 10-09-2012, 05:10 PM   #64
Sounds like you need to test the injectors. I've never ran upon this before but there's only one way to find out. There is a note in the stickies that I remember seeing. Sounds like tools won't be too bad.
Old 10-09-2012, 05:19 PM   #65
Moyhuerta's Avatar
Probably cuz its weierd i now dis is a illegal but dis my help a lil bit more befor i put the new iac i had raced my friends stang nd i beat him by like 4 cars nd now dat i put the new iac nd conected my intake i raced him agien nd we were head to head idk wat happend
Old 10-09-2012, 05:34 PM   #66
Lord knows I'd only run em on a track. I've got 2 kids and a wife to come home to. But hearing your description, I would think that your problem goes deeper than the IAC.
Old 10-09-2012, 11:42 PM   #67
Moyhuerta's Avatar
Yea i understand im still to young for dat haha.....wat do u think it could be any advice or clues
Old 10-10-2012, 02:35 PM   #68
Dion11197's Avatar
Since its auto, have you tried manually shifting and it still only goes to 5k? Could be TPS....
Old 10-10-2012, 02:46 PM   #69
Moyhuerta's Avatar
Well my car is manuel nd it only picks up tp 5k in firts gear...but befor it didnt do dat i always used to redline it
Old 10-10-2012, 03:03 PM   #70
You may have "redlined" it one time to many and damaged your engine.
Do you hear any rattles or knocks?
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 11:50 AM
Wiring harness question StevieScoops 1979-1995 Mustang GT 2 03-08-2012 05:49 AM
maf Robbie94gt 1979-1995 Mustang GT 7 12-17-2011 07:58 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
02:05 AM
