Where can I find a MAF harness? - Mustang Evolution
Old 09-13-2012, 03:34 PM   #1
Moyhuerta's Avatar
I need help finding a MAF harness??? could anyone point me in the right direction?
Moyhuerta is offline   Reply With Quote
Old 09-14-2012, 12:02 AM   #2
Re: MAF harness
RJM Injection Tech
Old 09-14-2012, 03:39 PM   #3
Moyhuerta's Avatar
I have another question wen u instal a cold air intake do u have to disconect the battery after u r done for 5 min??
Old 09-14-2012, 04:07 PM   #4
Re: MAF harness
No, it's not necessary for a CAI.
Old 09-14-2012, 04:10 PM   #5
Moyhuerta's Avatar
Because my car idles to high its up to 2000rpm nd I changed my MAF nd it still idles high
Old 09-14-2012, 04:28 PM   #6
WhiteCobra94's Avatar
My car was idling 2000rpms after I changed throttle body's the turned out my IAC was bad!
Old 09-14-2012, 04:30 PM   #7
Moyhuerta's Avatar
I now this a stupid question to ask but wat is an iac
Old 09-14-2012, 04:33 PM   #8
Idle air control valve
---------- Post added at 04:33 PM ---------- Previous post was at 04:31 PM ----------
The IAC (idle air control ) and TPS (Throttle position sensor) are on the throttle body
Old 09-14-2012, 04:36 PM   #9
Moyhuerta's Avatar
Kk now I knoe wat u r talking about...cant I try abd clean it
Old 09-14-2012, 04:41 PM   #10
I sure you can but idk what you would use.
Old 09-14-2012, 04:43 PM   #11
Moyhuerta's Avatar
Well I looked it up right now nd u could use carb cleaner
Old 09-14-2012, 06:00 PM   #12
91notchback's Avatar
Make sure you get a spray that's safe for fuel injectors. (Not sure if it will matter in the IAC, but better safe than sorry!) And check your voltage at the TPS. Instructions in the stickies under useful info.
91notchback is offline   Reply With Quote
Old 09-14-2012, 06:03 PM   #13
Moyhuerta's Avatar
Haha for reals....wat is tps
Old 09-14-2012, 06:17 PM   #14
Throttle position sensor. It should have .99-.98 volts at closed throttle. As you crank the throttle open it should steadily climb. I believe it shouldn't go over 4.5 volts at wide open throttle. (taking that number off top of my head but it's close) Repeat a few times and see if you come up with similar numbers.
---------- Post added at 07:17 PM ---------- Previous post was at 07:09 PM ----------
I had a 95 that would idle around 1800. Made pulling up next to cops and pushin in the clutch....interesting! It was a bad TPS.
Old 09-14-2012, 06:20 PM   #15
Moyhuerta's Avatar
Would I have to take off the intake to do dat
Old 09-14-2012, 06:24 PM   #16
No. It's on top of the throttle body.
Old 09-14-2012, 06:29 PM   #17
Moyhuerta's Avatar
Wat do u think I should try first
Old 09-14-2012, 06:42 PM   #18
Try one and if it don't work, try the next...lol The only thing that'll get to the bottom of the problem is one thing at a time. Me and WhiteCobra94 were just speaking from experiences we've had. Ones just as good of a starting place as the other.
Old 09-14-2012, 06:50 PM   #19
Moyhuerta's Avatar
Oh alright ill try both..thanx for the help
Old 09-14-2012, 06:54 PM   #20
Good luck man. I would pick up a Chiltons manual. That and this forum have gotten me through a lot!lol +5.0
Old 09-14-2012, 06:56 PM   #21
haha me to. + 5.8
Old 09-14-2012, 07:00 PM   #22
Moyhuerta's Avatar
Thanx...i think I am going to get one
Old 09-15-2012, 09:31 AM   #23
Dion11197's Avatar
Yeah, the guys on here are great resources!!
Also when you clean the idle air control valve, check the gasket too. After you clean it, if it still idles high all the time and not surging it could be a vacuum leak also. If the idle surges after still, you may need a new idle air control valve. But do the simple inexpensive checks and clean they mentioned first then go from there.
Dion11197 is offline   Reply With Quote
Old 09-16-2012, 11:32 AM   #24
Moyhuerta's Avatar
Oh alright thanks man
Old 09-19-2012, 05:55 AM   #25
Dion11197's Avatar
Any update?
Old 09-19-2012, 10:08 AM   #26
Moyhuerta's Avatar
No not yet ive been busy..but by today or tomarrow I will give u an update
Old 09-20-2012, 08:51 AM   #27
Dion11197's Avatar
I know how that goes, lol!
Old 09-20-2012, 03:33 PM   #28
Moyhuerta's Avatar
It didnt work my car idles the same it stays at 2000 nd it dosnt go down
Old 09-20-2012, 03:38 PM   #29
What did you try? If your TPS voltage is off, you can drill out the slots and usually fix it without getting a new one.
---------- Post added at 04:38 PM ---------- Previous post was at 04:36 PM ----------
The sensor is usually bad only when it gets past that 4.5-5 volts at WOT.
Old 09-20-2012, 03:41 PM   #30
Moyhuerta's Avatar
Well I try cleaning my iac wit the throttel body cleaner but it didnt work
Old 09-20-2012, 04:01 PM   #31
Now...move on to the next possible solution. It's the only way to clear these things up. And you will pick up a lot of knowledge while you're at it.
Old 09-20-2012, 04:02 PM   #32
Moyhuerta's Avatar
The problem is dat I dont understand the next thing u guys told me
Old 09-20-2012, 04:05 PM   #33
To check the throttle position sensor, you will need a digital multimeter. (one with instructions will tell you where your leads and dial will need to be.) Not sure if any lend a tool programs do this. If you get that, I will walk you step by step through the process.
Old 09-20-2012, 04:13 PM   #34
Moyhuerta's Avatar
Im going to have to buy one cus I dont have one wit me
Old 09-20-2012, 04:19 PM   #35
its a great investment.
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 11:50 AM
Wiring harness question StevieScoops 1979-1995 Mustang GT 2 03-08-2012 05:49 AM
maf Robbie94gt 1979-1995 Mustang GT 7 12-17-2011 07:58 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
04:32 AM
