Transmission pops out of first gear? - Mustang Evolution
Old 09-16-2012, 08:18 AM   #1
Sn95fitty's Avatar
Over the past 400 miles or so 1st gear started popping out more and more.. its pissing me off too.. lol. What do I need to do to fox this? New syncros? New tranny? I was also told that I should try a thicker tranny oil and it should help... What you guys think?? It has the royal purple syncromax in it now..
Sn95fitty is offline   Reply With Quote
Old 09-16-2012, 08:20 AM   #2
deadsp0t's Avatar
Rebuild or replace. Be carful as all it takes is on time popping out can break it.
That's unimpressive
Old 09-16-2012, 08:27 AM   #3
Re: 1st gear pop outs..
Needs a rebuild or replacement.The gears are worn or the shifting forks are bent.
Old 09-16-2012, 08:29 AM   #4
Sn95fitty's Avatar
What price range roughly?
Old 09-16-2012, 08:30 AM   #5
deadsp0t's Avatar
$1300 for a brand new one
That's unimpressive
Old 09-16-2012, 08:46 AM   #6
ColeJohnson's Avatar
You're looking at $1200-1500 for a brand new one and probably the same or more to rebuild yours...
2016 Comp Orange GT (current)
Old 09-16-2012, 08:48 AM   #7
The tip of the main shaft resides in the back of the input shaft which has a bearing made of rollers. The rollers and/ or tip of the main shaft could be shot. Makes the shafts move around.
The synchros can be worn out too. Needs to come apart.
9341088mmturbo is offline   Reply With Quote
Old 09-16-2012, 08:49 AM   #8
deadsp0t's Avatar
A new T5 is $1295 on basically every Mustang parts site. Just to clarify anything beyond $1300 will be for a different, stronger transmission.
That's unimpressive
Old 09-16-2012, 02:04 PM   #9
Sn95fitty's Avatar
Damn... I might just sell it and get a bike.. or trade for one..
Old 09-16-2012, 05:14 PM   #10
5.slow's Avatar
Region: Delaware
A guy on Baltimore Craigslist sells them rebuilt for 690 with your core. I know someone who bought one and it was a good tranny. Went high 11s on it without a problem.
5.slow is offline   Reply With Quote
Old 09-16-2012, 05:17 PM   #11
Jegs sell a t5 rebuild kit for like 350 i believe. 1300 for a rebuild KIT is crazy!
keaton5.0 is offline   Reply With Quote
Old 09-16-2012, 05:20 PM   #12
Sn95fitty's Avatar
Thanks I'll check that out..
---------- Post added at 02:20 PM ---------- Previous post was at 02:19 PM ----------
Yeah I saw that too..
Old 09-16-2012, 07:16 PM   #13
Blown347's Avatar
A t-5 rebuild here in southern California is anywhere from 800-1000 rebuilding with OEM spec parts.
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-16-2012, 07:18 PM   #14
He is probably talking with labor. Not to many people pike tackling that in there garage.
Old 09-17-2012, 04:52 AM   #15
Ah good catch. I read an article on rebuilding a t5, in muscle mustangs and fast fords i believe, and it isnt as difficult of a task as most people think it is.
Old 09-17-2012, 05:36 AM   #16
If you guys are talking about deadsp0t's post, he is talking about new transmissions, not a rebuild kit.
No, it is not very difficult, but I'd bet a rebuild kit is not going to have the parts you may need for this issue.
Old 09-17-2012, 05:48 AM   #17
I was more talking of this. And what keaton said.
Old 09-17-2012, 06:20 AM   #18
Ok, when he mentioned $1300 I figured he was referring to deadsp0t's post.
Old 09-17-2012, 06:28 AM   #19
You can use a trainny liquid called Trans X I got the same problem and after I used that thing all my problems were gone!!! That thing cost like 10 bucks at a local O'Reilly or any other store
fatto is offline   Reply With Quote
Old 09-17-2012, 06:36 AM   #20
Forum Car Trader
90GTNovi2000's Avatar
That's a bandaid on a bullet wound!!! Ouch. It needs a fresh trans
90GTNovi2000 is offline   Reply With Quote
Old 09-17-2012, 06:45 AM   #21
That price was based on a shop's quote for parts and labor on a quality rebuilt for parts that are rated for a little heavier duty but still close to stock.. Ended up being right at $1450.
Or $1200-1300 for a straight up new one.
Either way.
Rebuild kits are like $350-400 and shop's labor includes time to take the tranny out, time to rebuild, and time to put it in. They quote take out time at 1.5 hours and put in time at 1.5 hours.. When shop rate are around $110/hr labor gets expensive quickly.
Old 09-17-2012, 06:48 AM   #22
If you decide to keep it and replace the trans now is the time to decide how far you want to go with your power. Instead of buying another stock t5 now and later build the car to make more power than the t5 can take and have to spend more on an upgraded trans
Old 09-17-2012, 06:56 AM   #23
^^What he said.
While a "snake oil" treatment may or may not make a difference, it is definitely setting you up to do even more damage to your transmission.
I would remove the trans and tear it down to determine what the problem is, then you can decide whether a rebuild or replacement is needed.
P.S. While researching this issue I read that worn bearings can also cause them to pop out of gear, so it's possible that just a regular overhaul kit can cure your problem.
Old 09-17-2012, 02:04 PM   #24
Sn95fitty's Avatar
Originally Posted by Trojan Horse
^^What he said.
Ok I'll look into that..
So a guy I work with said that on the shift linkage there should be an adjustment to fix the issue.. Thoughts??
When our boss takes off we're gunna put it up on the lift to see if we can find something like that..
And also if it helps, it only does it if im taking off normal or slow.. but if I basically launch it then it stays in gear..
Old 09-18-2012, 01:59 AM   #25
The "linkage" is internal and it is not adjustable that I know of.
Won't do you any good to put it on a lift.
If you do not have an aftermarket shifter with adjustable stops to keep you from over shifting, there is a good chance you have bent the shifting forks.
Old 09-18-2012, 02:12 AM   #26
Sn95fitty's Avatar
Thats probably what it is.. what kinda fix is that?
Old 09-18-2012, 02:16 AM   #27
Same thing basically, tear it down, put in a rebuild kit and replace the damaged forks.
What would it take for a 2012 v6 to beat a 2009 v8 ? geepoons 2011-2014 V6 Mustang 84 09-04-2012 11:57 AM
Newbie: Is this normal? (Finding first gear & backfiring) Rim 2011-2014 V6 Mustang 9 03-07-2012 07:10 AM
87 AOD rebuild bcosta56 1979-1995 Mustang GT 15 03-04-2012 10:47 AM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 02:30 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 08:41 PM
05:14 AM
