What is this tube under my car? - Mustang Evolution
Old 09-17-2012, 07:41 PM   #1
Matt95GT's Avatar
Crawled under my car today to fix a loose bolt on my exhaust and saw this. I have idea what is. After I fixed my exhaust this thing start sounding like a small foghorn at random times.
Matt95GT is offline   Reply With Quote
Old 09-17-2012, 07:51 PM   #2
aegischief's Avatar
Looks like the smog recirculating tube.
aegischief is offline   Reply With Quote
Old 09-17-2012, 08:08 PM   #3
Matt95GT's Avatar
Is there a way to make it quieter?
Old 09-17-2012, 08:28 PM   #4
aegischief's Avatar
It should be connected from your h-pipe to the smog pump.
Old 09-17-2012, 08:48 PM   #5
maldog's Avatar
Region: Nevada
Re: What is this?
+1
The end of the tube is shinny showing where it was connected. It looks like you lost part of the tube due to vibration?
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 09-17-2012, 09:11 PM   #6
Matt95GT's Avatar
Can it be connected to anywhere on the pipe?
Thanks for the help. I'm new troubleshooting problems so this is all new to me.
Old 09-17-2012, 10:05 PM   #7
Blown347's Avatar
Re: What is this?
a Catted H-pipe should have an inlet on it to connect it If i am not mistaken. If you're not worried about smog then you can remove the whole thing
Blown347 is offline   Reply With Quote
Old 09-17-2012, 10:34 PM   #8
Filibuster
If you don't have cats anymore it no longer serves the purpose of pumping air to the cats..if it's making noise the easiest thing to do is run a shorter belt and bypass the smog pump. it'll also free up couple horsies
oh and if you don't have cats and hook it up you may get some popping in the exhaust kinda like a small backfire.
XXSTEVEO66 is offline   Reply With Quote
Old 09-18-2012, 12:16 AM   #9
Matt95GT's Avatar
No cats... If I change the belt and bypass the smog pump would would that fail an emissions test for state inspection?
Old 09-18-2012, 04:37 AM   #10
aegischief's Avatar
If you don't have any cats you are going to fail an emissions test. Easiest thing to do is block off the tube by bending it over or plugging it off.
Old 09-18-2012, 10:51 AM   #11
Re: What is this?
Yes, but he won't pass emissions inspections if it is not hooked up and you wouldn't want to just block it without disabling the pump either.
Old 09-18-2012, 11:49 AM   #12
Blown347's Avatar
Re: What is this?
You can leave your smog pump in and just unplug everything from it, but like the guys said you won't pass smog. but if you don't have cats, you automatically fail regardless.
Old 09-18-2012, 09:54 PM   #13
Matt95GT's Avatar
Thanks for the help guys! I really do appreciate it! All this is extremely new to me.
Old 09-19-2012, 09:32 AM   #14
Blown347's Avatar
Any time buddy
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Old 09-19-2012, 10:48 AM   #15
MC770's Avatar
Re: What is this tube under my car?
Depends on the state in NC if its 1997 or older no emissioins test is required
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 09-19-2012, 11:42 AM   #16
Matt95GT's Avatar
Here in Texas we do emission test by county. More populated counties do emissions testing no matter what. Less populated counties don't do emissions on 98 or newer.
Either way I'll fail. I don't have cats but I have until next march to get it fixed.
Old 09-19-2012, 12:34 PM   #17
Blown347's Avatar
Eh you can just find a hookup and get a smog cert nobody wants cats anyway haha
Old 09-20-2012, 07:38 AM   #18
MC770's Avatar
Thats a pretty interesting way of doing the testing haha I'd be out of luck if we did it that way here in NC
Old 09-20-2012, 08:32 AM   #19
That's how indiana is. The way they figure out which counties do smog is by the amount of pollution in the area. We have a lot of big steel mills in my area, so the counties in that area do smog. But the next counties over don't. So I use someone else's address to get by the system.
First Car, Hi there :D Jetsnix New Member Introductions & Greetings 14 08-20-2014 06:05 PM
my car will die and start right back up again! HELP Josh.0 Pre-2005 V6 Mustang 25 06-07-2012 11:47 AM
2005 Mustang GT 350 Tribute Car (Mineral Grey Lovers) 2K05GT Pictures and Videos 8 02-01-2012 04:43 AM
97 GT Smelling gas fumes in car Sharky97 1996-2004 Mustang GT 2 09-20-2011 02:54 PM
02:40 AM
