1990 Mustang one wheel spinning issue? - Mustang Evolution
Old 09-18-2012, 12:31 PM   #1
Kresly's Avatar
Only one wheel spins and I want two. Any ways to do that short of buying a new rear end
Kresly is offline   Reply With Quote
Old 09-18-2012, 02:00 PM   #2
Re: 1990 foxbody rear end lock
If you already have the 8.8 Traction Lock rear end, it probably needs to be rebuilt.
Old 09-18-2012, 11:05 PM   #3
Kresly's Avatar
Well idk if I do or not. Lol
Old 09-19-2012, 05:13 AM   #4
You most likely do. The t lock came stock.
Old 09-19-2012, 08:00 AM   #5
Yup, if you have a GT/LX with the 5.0 engine it is a T-lock.
Old 09-19-2012, 09:06 AM   #6
Blown347's Avatar
Yea that's a sign that your rearend is pretty much done for. You can just have it rebuilt
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-19-2012, 10:43 AM   #7
Kresly's Avatar
How much would it cost me to have it rebuilt or would I be better off puling it off another body
Old 09-19-2012, 12:30 PM   #8
A rebuild kit is pretty cheap. Your also gonna want to put all new bearing in the rear while its out. What will cost is the labor if your not able to do the work yourself. The whole carrier will need reset. Part are probably 1-200$. But labor could be anywhere from 500-1000$ depending.
Old 09-19-2012, 12:39 PM   #9
Blown347's Avatar
Even if you've never done it, I'd say grab a chitons manual and give it a go. I don't think it's really hard, just a little tedious
Old 09-19-2012, 09:57 PM   #10
Kresly's Avatar
Hadn't thought of that. May take me a bit but it's a learning experience
Old 09-20-2012, 03:57 PM   #11
Blown347's Avatar
And if all else fails, removing the rear end takes maybe an hour. So if u screw it up you can just take it in. But I don't think you will. I've never rebuilt mine per say, but I've had the whole thig apart and it's pretty easy to assemble.
Old 09-20-2012, 11:34 PM   #12
93_347foxbody's Avatar
I think I'm having the same issues. I know I have a posi rear but when I burn out only my right tire leaves a mark. The rebuild kits on am are cheap so I'm gonna pick one up. Never took a rear apart but my friends done a few before so I figured with him and my haynes manual I should be good
93_347foxbody is offline   Reply With Quote
Old 09-23-2012, 08:44 PM   #13
Kresly's Avatar
Yea I would think so. Just gotta find the money to do so.
Old 10-25-2012, 02:15 AM   #14
lilrafe87's Avatar
Just replaced my locker. The clutches broke on mine and bought one from a buddy for 50. Installed it and what a difference. Pretty sure your clutches are smoked. Cheapest clutch set I found was 70. Good luck
lilrafe87 is offline   Reply With Quote
Old 10-25-2012, 04:47 PM   #15
Kresly's Avatar
I recently bought another fox shell for 100. Did a rear end swap and it is limited slip and I love it. I also have a rear main seale leak so gotta fix that an replace my clutch. Have a stage 2 in it now. To put in the same is like $330. Insane
1990 mustang
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
1990 mustang GT mustangcobra90 1979-1995 Mustang GT 12 06-25-2011 10:29 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
10:26 AM
