fuel filter - Mustang Evolution
Old 03-30-2008, 07:03 AM   #1
fuel filter
i have a 95 gt do u have to drop the gas tank to replace the fuel filter...how do u go about replacing it????
95blackgt is offline   Reply With Quote
Old 03-30-2008, 08:46 AM   #2
Re: fuel filter
its on the passenger side above the rear axle you need a line tool to remove it, I think yours is 5/16th line. Just use the tool (relax and take your time and dont force it) and it will come out. Then be ready to taste gas (wear something to protect your eyes lol) after that pop in the new one.
change them EVERY 10k miles
Old 03-30-2008, 05:14 PM   #3
Scut95's Avatar
Re: fuel filter
You might not even need a line tool...i think mine just had hose clamps that you can undo with a screw driver.....but easy to do so don't fret
Old 03-30-2008, 05:26 PM   #4
Re: fuel filter
i would rather have a line tool so you dont mess up anything
Old 11-11-2008, 09:07 PM   #5
Re: fuel filter
i just changed mine last night.. theres two little clips you spread apart pull down a little bit and then push the ends in and then finish pushing them down and then the line pulls right off.. remember to relieve the fuel pressure.. its about a 10 min job
95GTBME is offline   Reply With Quote
Old 11-11-2008, 10:27 PM   #6
Re: fuel filter
yea the sn95's has the nylon clips that did not require the quick disconnect tool for the fuel filter, like stated above u can spread the prongs or pry with a screwdriver on the flat edge to release the nylon clips. alot of new fuel filter brands do not include new nylon clips so be sure not to lose them if they are not supplied. when the new edges came out, they started a different method which required using the quick disconnect tool.
96 GT- Who knows what's in it.
Fuel filter? OHHitsKB Pre-2005 V6 Mustang 9 07-12-2010 11:19 AM
fuel filter upton7 1996-2004 Mustang GT 18 02-10-2010 07:07 AM
99 fuel filter jilly filly Pre-2005 V6 Mustang 6 07-10-2007 11:44 PM
fuel filter help? 01mineralgrey6 1996-2004 Mustang GT 13 08-14-2005 09:39 AM
fuel filter HELP project232 Pre-2005 V6 Mustang 3 04-16-2005 07:54 PM
03:51 PM
