Fuel pressure problem? - Mustang Evolution
Old 09-18-2012, 08:55 PM   #1
thomas91gt's Avatar
Is 32 psi to low I been having issues lack of power misses terribly on start up idles fine after about 5 mins of runtime but no power. If it sits for maybe 2hrs or so when I start it back up it runs like crap again for about 5 mins. I have pretty much checked and tested every sensor that I am aware of other than the act sensor, i set timing ect only thing I can figure out is maybe fuel pressure??? Or blown head gasket between cylinders thought I had done a pretty thorough compression check but maybe not lol. O and it always seems to be running rich and about have throttle there is a dead spot in power
---------- Post added at 09:55 PM ---------- Previous post was at 09:53 PM ----------
Any input is appreciated this thing is getting on my last nerve lol... And it is completely stock
thomas91gt is offline   Reply With Quote
Old 09-18-2012, 09:43 PM   #2
watson 1025's Avatar
I'm pretty sure that's a little low. Its supposed to be closer to 40 psi.
watson 1025 is offline   Reply With Quote
Old 09-18-2012, 10:05 PM   #3
Re: Fuel pressure
What about a leaking injector..When the pressure comes up on the gauge during a key on engine off,,does it slowly drop off,,that could indicate a stuck open injector,,Also check the fuel filter,,if the pressures low
mymustang is offline   Reply With Quote
Old 09-19-2012, 07:37 AM   #4
thomas91gt's Avatar
Yea im kinda thinking injector cuz it has always seemed to run really rich
---------- Post added at 08:37 AM ---------- Previous post was at 08:33 AM ----------
Thats what i thought 38-40 with it unplugged I guess that would be the reason for it backfiring on startup as well.
Old 09-19-2012, 08:11 AM   #5
Re: Fuel pressure
Your fuel pressure should be 38-40 with the engine idling and the vacuum hose on the regulator removed and plugged off. When you reconnect the vacuum hose the fuel pressure will drop some.
You should also check your timing. Don't forget to remove the spout plug before checking/setting and to replace it afterwards.
If you do not have a Chiltons manual for your car, get one. They contain a lot of specs and procedures for testing and working on your car.
Old 09-19-2012, 03:59 PM   #6
thomas91gt's Avatar
Yea i have a haynes it has some im gonna get me a chilton
Old 09-19-2012, 05:46 PM   #7
I prefer Chilton over Haynes. But with that said I only have a Haynes. If your gonna fork up money for another book I would recommend getting the ford service manual. It can be had for around 30$ and will blow both books put together out of the water.
Old 09-19-2012, 07:09 PM   #8
thomas91gt's Avatar
I work at a parts store ill exchange it lol
Old 10-08-2012, 10:27 AM   #9
thomas91gt's Avatar
the fuel pressure is supposed to rise as u rev the engine right? it just seems like it floods itself out at higher rpm especially if the throttle is wide open
Old 10-12-2012, 09:13 PM   #10
thomas91gt's Avatar
I believe I may have a faulty fuel injector how long should the fuel system hold pressure I put a gauge on it had 32 when I left came back in 4hrs and it was 0 would this be normal or could I possibly have a leaking injector
Old 10-12-2012, 09:18 PM   #11
Bleem@1's Avatar
That could indicate a leaky injector or regulator either one. Run some tech rpm through it and see if it helps. If it affects it at all it is the injectors. How hard to start is it?
Bleem@1 is offline   Reply With Quote
Old 10-12-2012, 09:23 PM   #12
thomas91gt's Avatar
Easy to start but it runs rough for like 2mins then clears but doesn't have power that it should and at wot its like it has a rev limiter
---------- Post added at 10:23 PM ---------- Previous post was at 10:22 PM ----------
But if it sits for a while it runs rough again... And smells really rich
Old 10-12-2012, 09:25 PM   #13
Bleem@1's Avatar
Tech rpm shoulda been techron. Frickin auto correct. Have u checked TFI module in distributor?
Old 10-12-2012, 09:50 PM   #14
thomas91gt's Avatar
Yea checked and replaced those and tps and set at 1., iac, egr, set timing to 12btdc
Old 10-12-2012, 09:53 PM   #15
Bleem@1's Avatar
Did you replace pick up coil also(hall effect switch) in distributor?
Old 10-12-2012, 10:04 PM   #16
thomas91gt's Avatar
Yea the whole dist. Cuz it was easier
Old 10-13-2012, 06:00 AM   #17
Bleem@1's Avatar
If it was me I would run a can of techron through it and see if it helps
Old 10-13-2012, 08:02 AM   #18
Jeff44's Avatar
For the he'll of it, I would change the fuel filter. It's cheap enough and easy to do.
Jeff44 is offline   Reply With Quote
Old 10-13-2012, 10:05 AM   #19
thomas91gt's Avatar
Yea im gonna do that today and take my plugs out and see if i can tell if one is burning to much fuel
Possible fuel pump problem? yvega05 1979-1995 Mustang GT 4 09-18-2012 11:03 AM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
Fuel problem help! NateNasty 1979-1995 Mustang GT 51 09-13-2011 03:37 PM
fuel pressure gauge XXSTEVEO66 1979-1995 Mustang GT 9 08-12-2011 03:02 PM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
09:40 AM
