will this water pump fit? - Mustang Evolution
Old 09-19-2012, 07:35 PM   #1
Sn95fitty's Avatar
just like the title says.. just want to be sure before i order it..
Ford Racing Part No. M-8501-D50 - Water Pumps
Sn95fitty is offline   Reply With Quote
Old 09-19-2012, 07:52 PM   #2
Re: will this water pump fit?
No, that is a standard rotation pump. It won't work on your car, you need a reverse rotation pump.
I searched the site for your car's water pump and they did not list any.
Old 09-19-2012, 08:13 PM   #3
Sn95fitty's Avatar
Thanks, i wasnt sure if that was the one or not.. i'll look arround a bit more..
Old 09-19-2012, 08:33 PM   #4
Sn95fitty's Avatar
So i cant find this water pump without the other piece as part of the kit?
Cooling System Parts
Old 09-19-2012, 08:47 PM   #5
i scored my water pump from ebay. i wanna say i paid around 38$. and it was brand new in box. it also looks and works great. i have also got them from summit racing cheaper than that i believe.
Old 09-19-2012, 09:04 PM   #6
Sn95fitty's Avatar
yeah i just cant trust ebay lol.. but ill look on summit.. also, will a 93 5.0 water pump fit my 95 5.0?? i dont see why it wouldnt, lol but im a noob to this mustang thing..
Old 09-19-2012, 09:11 PM   #7
I personally don't recall what rotation the 95s are. When you look at summit. Use the filter tools on the left side of the page on summit racing. As long is the year is correct it will fit. You can also looks at the parts on websites and they will give you the range that the pumps fit. For instance, if it say 87-93 or 87-95 then you should have your answer.
Old 09-19-2012, 09:16 PM   #8
Sn95fitty's Avatar
ok cool thanks.. this is what i found.. wish i could get a ford racing one though..
http://www.summitracing.com/parts/GMB-125-1920/All/
Also, since i'll have it all apart anyways, should i do a 180 degree thermostat?? ive seen people talk bout it but not sure if i should do it or not..
Old 09-19-2012, 09:19 PM   #9
Cool. It even says high flow design in the description. I didn't verify year or anything, but looks good to me.
Old 09-19-2012, 09:25 PM   #10
Sn95fitty's Avatar
yeah i saw that too.. thanks for the help.. any thoughts on the thermostat question?
Old 09-19-2012, 09:32 PM   #11
I would run stock temp thermostat. 185-195 will suffice. I think stock is 193*.Some people get away with running lower but its not good for the life of your motor. Engine oil is designed to lubricate best at above 180*. If you run a cold thermostat it will take a long time to fully warm up the engine. Which will shorten the life of your motor. What you can do is run a high flow thermostat. I use a high flow miloden that I picked up from summit also for 10-12$ I think.
08:55 AM
