94 Mustang runs worse after CAI & coil install, Need suggestions - Mustang Evolution
Old 09-20-2012, 09:38 AM   #1
Mustang52's Avatar
I have a 94 automatic 5.0 I was running 16 bone stock which is ehh ok so I put a cold air intake and new coil on ran it last night and ran an 18 and it starts braking up at 4000 rpms snd its running really rich went through checked for vacuumed leaks none put the computer on it said it was all good so idk what to do now
Mustang52 is offline   Reply With Quote
Old 09-20-2012, 01:34 PM   #2
Re: Need suggestions
There were no codes? That's strange.
I would suspect issues with the MAF since you just installed a CAI and it happened after the install. Check the wiring and clean the sensor. You should also check your timing and make sure the coil connections are good.
Old 09-20-2012, 02:57 PM   #3
+1 also if you used a oil type filter make sure you didn't over oil it and followed the proper procedures.
Old 09-21-2012, 01:24 PM   #4
Mustang52's Avatar
Ok so I got a new maf it's not breaking up any more but when I took the old one off it was full of oil what should I do about it?
Old 09-21-2012, 01:40 PM   #5
Check your pcv valve maybe. Unless its oil from the air filter like I alread suggested. Sorry I can load the pic at the moment.
Old 09-21-2012, 11:22 PM   #6
Re: 94 Mustang runs worse after CAI & coil install, Need suggestions
That will cause some issues. You probably could have just cleaned that one.
You need to identify where the oil is coming from, possibly the screen in the PCV and maybe the valve like dream said.
If it is a continuing issue from worn rings and excessive blow by, you can install an (Link>) oil separator to remove the oil. Might not be a bad idea anyways.
cai
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
12:51 AM
