Timing marks off, what gives? - Page 2 - Mustang Evolution
Old 09-24-2012, 07:46 PM   #36
Originally Posted by Azure
I was asking TH a while back about how you would know what weight the HB would need to be, like would the builder of the engine only know? If I remember right, it was the weight of the crankshaft or something like that there, right?
the crankshaft imbalance.
but i dont know what stock is or if it matters what crankshaft he has.
Old 09-24-2012, 07:47 PM   #37
Blown347's Avatar
Well yea so far as how you're engine is balanced, there are 3 options for a 5.0. there is a 50oz external imbalance (stock later 5.0s) an Internal balance, which has to be done by a machine shop, or its like a 28oz imbalance(early 5.0s) but apart from that spec there are weights to tweak that balance slightly. How would i know whether or not i need them?
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-24-2012, 07:49 PM   #38
i bet trojan knows this one..
Old 09-24-2012, 07:55 PM   #39
Filibuster
Okay I mean I've Removed one before, and the tool is definitely a must, but my question is that they all come with the spaces for little counterweights. Summit's instructions don't say anything about using them. but how would i know if i need them and where?
Don't you love when somebody gives an lil answer and you're like *gah I'm not fukin stupid*
Ha!..but yeah im sure TH knows somethin boot this.
XXSTEVEO66 is offline   Reply With Quote
Old 09-24-2012, 07:57 PM   #40
lol^
Old 09-24-2012, 08:21 PM   #41
Blown347's Avatar
haha i hope so.
Old 09-24-2012, 09:45 PM   #42
You need to be sure which your rotating assembly is 50, 28 or neutral.
Did you get a build sheet with the engine?
If not, just make sure whatever you put on there matches what you take off, otherwise your engine will shake itself to death.
Old 09-24-2012, 10:06 PM   #43
Blown347's Avatar
I bought the car with the engine built, I've just since had it rebuilt with some minor tweaks. It still accepts a 50oz imbalance flywheel, but what about those little counter weights? what are those for?
Old 09-25-2012, 11:19 AM   #44
If they came with the new balancer, then they are used to balance it to whatever imbalance you need. As far as I know there should only be two of them. Neutral balance is using no weights, 28 oz is using the smaller weight and 50 oz is using the largest weight.
Old 09-26-2012, 12:30 PM   #45
Blown347's Avatar
Okay so I got my balancer today, and it doesn't even have the little pin weights I was referring to, so hopefully this works!
Old 09-26-2012, 07:59 PM   #46
What did you buy?
Old 09-26-2012, 09:47 PM   #47
Blown347's Avatar
What did you buy?
It's the summit racing bracket racer balancer. It's pretty beefy I dot think I will break this one haha
Old 09-26-2012, 10:08 PM   #48
Did you determine for sure which imbalance you needed before you ordered it. If not and it is wrong and you install it they probably won't take it back.
Let's hope you don't, but it does not have the extended keyway or HD hub for blower use.
03:36 AM
