low voltage - Mustang Evolution
Old 03-31-2008, 02:45 PM   #1
low voltage
i have a 93 coupe with a 351w swap it will not start it has low volts (4.3) to the injectors and no pulse. but it will fire up on starter fluid any ideas i think ecu
calvin6199 is offline   Reply With Quote
Old 04-03-2008, 08:53 PM   #2
silverstangboy's Avatar
Re: low voltage
sounds like you have a ground issue with your harness, re-check all of your connections if the ECU was hindering injector pulse the car would not start at all.
this is actually how my homebrew anti theft works
Mustang FAQ - Engine Tech, Air Bag, ABS, Brake Home Page
93 mustang notch
~450hp 331 stroker - Sold
Old 04-03-2008, 09:04 PM   #3
Re: low voltage
it only starts if i spray starter fluid in the intake it has no pulse from ecu at all put does have 4.3v to the injectors
Old 04-04-2008, 06:55 PM   #4
Re: low voltage
when does it give 4.3volts? key on engine off? or when the injector pulses?
you should see a full 12v when the injector fires, but partial voltage when in normal state, as the computer monitors the condition of the injector with that voltage.
one way to see if the computer is telling the injectors to pulse is tie in a 12v light in parallel with the injector, it should light up when the injector fires.
another thing to check, is your fuel pump relay turning on?
93 mustang notch
Old 04-06-2008, 08:00 PM   #5
Re: low voltage
no volts with key off. 4.3 with key on. absulutly no pulse when the key is in the start position. the fuel pump is on and will suppy as much presure as i want. it is set at 55psi right know. it has no ground any time key on, key off, or in start position. the injectors are suposed to have 12v as long as key is on and a ground on and off to pulse the injector. i have a noid light it does not flash
Old 04-10-2008, 06:51 AM   #6
Re: low voltage
ah, I see what your saying, your checking the harness to a known good ground and only getting 4.3 volts, I thought you were checking it against the injector ground which would not show a full 12V, but you are right, system is 12v hot when on and computer provides a true ground when it wants the injector to fire.
this diagram should help you with some questions, you may be right about the computer
i'll try to help you with anymore questions.. im working alot of hours right now though.
check your injector to a known ground to see if it is outputing 12V, then if not go through and check all your electrical connectors for good continuity, i'd also check pin #37 at the computer itself.
93 mustang notch
Secondary Air Injection System Monitor Circuit Low Voltage BruThru2002 Pre-2005 V6 Mustang 6 03-23-2011 04:02 PM
Looking for a set of low low ratio 7.5" gears PureVenom Pre-2005 V6 Mustang 4 08-13-2008 04:15 PM
03 Gt Pi Heads And Cams!!!! Low Miles/low Price alwaysthefinest Mustang Parts for Sale and Wanted 1 05-24-2007 05:17 PM
voltage regulator white 98 gt 1996-2004 Mustang GT 3 08-30-2006 03:00 PM
irregular voltage to the air filter mustangruss Pre-2005 V6 Mustang 5 11-21-2005 03:32 PM
12:13 PM
