Tranny and rear end identification help - Mustang Evolution
Old 09-23-2012, 11:21 AM   #1
351wFoxbody's Avatar
I have a'90 foxbody and I know it has a t5 trans, but I was wondering if there was a way to tell what generation it is, and I think I have a 3.73 rear end but I'm but sure, neither one is stock so I can't use any codes from the car(recently bought it and trying to learn it inside and out incase I encounter a problem)
351wFoxbody is offline   Reply With Quote
Old 09-23-2012, 11:33 AM   #2
there should be a id tag on the trans. it will have the number on it. there is a link in the useful information stickies thread that should help.
the rear end should also have a tag on it. but if it doesnt you can spin the tire one revolution and count how may times the driveshaft spins. 3 3/4 turn should be 3.73s
Old 09-23-2012, 12:53 PM   #3
Ok thanks a lot, do you know where the tag would be in the trans?
Old 09-23-2012, 12:56 PM   #4
i forget. either by the shifter or tailshaft. dont go by any numbers on the case. they wont be accurate.
Old 09-23-2012, 12:59 PM   #5
Will the tag be riveted on
Old 09-23-2012, 01:01 PM   #6
it should be hanging there. probably on wire
Old 09-23-2012, 01:02 PM   #7
Ok thanks a lot, huge help
Old 09-23-2012, 01:03 PM   #8
or bolted on. use this for reference.
http://www.britishv8.org/articles/bo...t5-id-tags.htm
ID:	69761   Click image for larger version
05:02 PM
