Cai in front of windshield - Mustang Evolution
Old 09-24-2012, 12:04 AM   #1
Dtibbz22's Avatar
If I were to mount my intake under my cowl right before the windshield (3 inch American muscle cowl) would i be suffocating the car? it would be a shorter distance from throttle body. But higher than throttle body. I don't believe I would suck in to much hot air but heat does rise any takes on this just trying to see if its better then in the wheel well.
Dtibbz22 is offline   Reply With Quote
Old 09-24-2012, 12:35 AM   #2
93slowstang's Avatar
It would be better in the well. The heats gotta go somewhere and you don't want to suck in that hot air coming out of the cowl. The air in the fender well is much cooler and denser.
Old 09-24-2012, 09:15 AM   #3
Site Sponsor
Sponsor
AMWill's Avatar
Re: Cai in front of windshield
I agree that you're better off routing the CAI into the fender. You'll have access to cooler air and make more power even thought the piping is longer. Then again, you could always just try your idea just for fun.
There are people who do something similar with carb. or 4 barrel throttle body intakes and have a block off shield that fits snug against the hood when it's closed. This way only cooler air comes in from the cowl and most of the heat from the engine can't seep through.
Maybe this will give you some new ideas for a future intake!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 09-24-2012, 11:23 AM   #4
Blown347's Avatar
Plus if your filter is above the throttle body you wouldn't be able to properly oil it, or the oil would run into your intake and that's bad
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-24-2012, 04:12 PM   #5
Dtibbz22's Avatar
I figured as much with the heat did not think of the oil. Now for cai setup with a breather valve could this possibly be a breather idea? I'm not thinking cone shaped filter I'm thinking straight. Just want something different and have plenty of room on the side of the block.
Old 09-26-2012, 10:25 AM   #6
A cowl hood is designed (or it is supposed to be designed) to take advantage of the low pressure area at the bottom of the vehicle's windshield and use that to suck the hot air out of the engine compartment. Assuming your hood is properly designed, you would be placing the air intake right in that hot air path. You would be MUCH better off placing it in the front fender well, where it can receive lots of cold air.
As to your second post, I don't have any idea what you are talking about. What is a CAI with a breather valve?
Old 09-27-2012, 09:56 AM   #7
Dtibbz22's Avatar
Basically I would run a tube on too of the piping before the throttle body to allow any excess hot air come right out of the cowl.
Old 09-27-2012, 11:36 AM   #8
Dtibbz22's Avatar
Think Baffle, throttle in valve sucked closed, off throttle valve releases warmer air escapes.
Old 09-27-2012, 12:13 PM   #9
Butch's Avatar
Region: New Mexico
I heard this idea a while back, Id like to do it, just cause it seems cool and high functional, , ad a intercooler and run everything to your TB
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 09-27-2012, 03:54 PM   #10
Dtibbz22's Avatar
Basically this with a baffle on top attached to throttle cable with a limiter to open it so you don't lose air when on throttle
cai
05:55 PM
