battery relocation - Mustang Evolution
Old 09-24-2012, 03:09 PM   #1
watson 1025's Avatar
battery relocation
I'm planning a 5.0 swap this winter and need to relocate my battery to the hatch sice it is where the intake will be for the 5.0. I know I need 1 negative ground to the block and 1 negative ground to the frame then 1 positive to the starter and 1 positive to the altinator. But do I have to run 2 positives all the way from the back or can I run 1 large gauge and split it in the engine bay?
watson 1025 is offline   Reply With Quote
Old 09-24-2012, 03:59 PM   #2
you maybe able to find a schematic online just for that job. also when you google search dont forget to try the image tab.
another option is buying a kit that comes with everything you need and probably instructions.
Old 09-24-2012, 04:09 PM   #3
I looked at kits and I already have most of what iis in the kit in my garage. I googled it but I didn't think of trying the image tab. Thanks for the tip!
Old 09-24-2012, 04:10 PM   #4
no problem. the image tab is where i find most of my eletrical and vacuum diagrams.
Old 09-24-2012, 04:17 PM   #5
Found a a diagramunder image on google. Thanks! The 5.0 setup is a little different from the 3.8 but I know how to do it now.
Old 09-24-2012, 04:18 PM   #6
your welcome and good luck.
if you need anything else feel free to ask.
Old 09-24-2012, 05:21 PM   #7
I have another question. I was looking at cut off switches and there a ton of different ones! How do I choose the right switch?
Old 09-24-2012, 05:24 PM   #8
as long as the style is what you want at the switch is rated for your system you should ok. but i dont know the rating you need off hand.
Old 09-24-2012, 05:24 PM   #9
also if you are doing this for track/ nhra rules then you will have to check those.
Old 09-24-2012, 05:29 PM   #10
As far as my car goes it almost completely stock as far as electrical goes. Just one sub and small amp.
Old 09-24-2012, 05:31 PM   #11
i would probably go by what the wire you are using is rated for. but maybe someone else will chime in with better info.
Old 09-24-2012, 06:41 PM   #12
I finally narrowed it down on summit with a little research. I found a few diagrams and the biggest difference is the ground. One has a 1 gauge from tge negative to the frame the ftom the frame to the block. The other is a 4 gauge from the negative straight to the block. Cant decide witch would be better. I want to do the 1 gauge way cuz its easier but idk about better...
Old 09-24-2012, 06:43 PM   #13
why is the 1 gauge easier? i would go with the one gauge to be sure its good.
Old 09-24-2012, 06:51 PM   #14
Cuz the 4 gauge diagram has me running a 15 ish foot long wire from the battery all the way from the hatch to the engine block. The other one just has me running a 2 foot long wire from the battery to the frame in the back then 2 foot long wire from the frame in the front to engine block.
Old 09-24-2012, 06:54 PM   #15
im sure either technique can be used no matter which route you go. it is essentially using the frame for the ground to travel to the back instead of running a solid wire all the way.
Old 09-24-2012, 06:58 PM   #16
Yeah, my only concern was will it conduct as well as running a wire the whole way? If it will then I no witch rout I wanna go.
Old 09-24-2012, 10:04 PM   #17
foxbox's Avatar
I bought a relocate kit and I was planning on just bolting the ground right to the floor of the hatch. Ill probably grind the floor clean and then weld a stud to the floor so I can just bolt the ground to that. Ill also probably have another ground from the motor block to the frame in addition to the one that is on the firewall. If that helps
foxbox is offline   Reply With Quote
Old 09-25-2012, 06:43 AM   #18
Quball19's Avatar
This is what trojan horse came up with on wiring
Quball19 is offline   Reply With Quote
Old 09-25-2012, 07:25 AM   #19
Y does there need to be a breaker wen there isnt one now? Is it because of the distance?
Old 09-25-2012, 08:56 AM   #20
Quball19's Avatar
Sorry bro can't answer that, this is info I got from TH
Old 09-25-2012, 09:20 AM   #21
Forum Car Trader
90GTNovi2000's Avatar
Good question I'm not sure either but it may keep you from over amping electronics or something but idk.. Or maybe if there is a short it will keep the msd and stuff from burning up..
90GTNovi2000 is offline   Reply With Quote
Old 09-25-2012, 09:29 AM   #22
Its all cool. I think I've counted 9 different diagrams that I've seen and I'm assuming they all work but I just want to know if one is better than the rest or if they all work the same.
Old 09-25-2012, 09:36 AM   #23
Quball19's Avatar
Yes believe it was from over amping, or any power surge that could cause problems
Old 09-25-2012, 09:37 AM   #24
Forum Car Trader
TH is better with wiring and will give reason to the diagram soon.. Although he hasn't been on in awhile that I'm aware of.
Old 09-25-2012, 09:41 AM   #25
Quball19's Avatar
Hope he is doing ok? But yes he will explain it better
Old 09-25-2012, 09:44 AM   #26
Forum Car Trader
He is fine!! Well to an extent.. It's administrator issues I believe.
Old 09-25-2012, 09:44 AM   #27
deadsp0t's Avatar
His issue has been resolved.
That's unimpressive
Old 09-26-2012, 09:44 AM   #28
Attachment 69981
That diagram is my own version as to how I intend to do my battery relocate. The breaker switch is as you surmised to help protect the long run length of the wires. If they shorted out with no breaker protection they could possibly cause a fire that would burn up the entire car.
I am doing the ground wiring as shown, because I have read of to many problems caused by just grounding to the frame. My way ensures proper grounding to the entire car, engine & ECU.
Old 09-26-2012, 10:37 AM   #29
Quball19's Avatar
Where can you get braided line at? You told me once but I believe I have slept since..... Lol
Old 09-26-2012, 11:36 AM   #30
A bit like me are you? McMaster.com
Grounding Braid, I think they call it.
Choose a size eqivalent or close to your positive battery cable size.
Old 09-27-2012, 06:54 AM   #31
Will it hurt anything if I use regular wire instead of the braided for ground and can I just use 200 amp fuses instead of breakers. I've never seen breakers for vehicle use but I know where I can get 200 amp fuses.
Old 09-27-2012, 07:04 PM   #32
No, you can use whatever you want.
Are you sure the 200A fuses are for 12 Volt DC use?
Link > 200 Amp 12 Volt Breaker
Old 09-27-2012, 08:12 PM   #33
yeah i was going to get them from a sound system shop. but i think the breakers u posted are just as much so i might get them instead.
Old 09-29-2012, 07:40 PM   #34
Well I got the relocation done! I think the engine bay looks a lot better and I'm also one step closer to getting a 5.0 n there. I was watching videos on youtube a few min ago and found a vid called cumstang. N e one else seen it? It was crazy!
Old 09-30-2012, 10:56 AM   #35
Yeah, It has a Cummins Diesel engine in it.
03:00 PM
