Help, idle problems. - Mustang Evolution
Old 09-24-2012, 04:12 PM   #1
1Mustang89's Avatar
I'll be driving and when I clutch my rpms go up and it makes the car jump, but I don't think it's the clutch it's my accelerator Getting stuck or something because when I gun it it stays at that rpm for a second and then will idle at 2k....but then stop doing that randomly.....?
1Mustang89 is offline   Reply With Quote
Old 09-25-2012, 11:40 AM   #2
91notchback's Avatar
For what it's worth, I had a 94 GT that would do that. Bad TPS sensor. Does it have any surge to the idle?
91notchback is offline   Reply With Quote
Old 09-25-2012, 12:09 PM   #3
1Mustang89's Avatar
It feels like the throttle gets stuck for a second and does it every now and then. I have a lot of play in my as pedal maybe my cable is bad?
Old 09-25-2012, 12:35 PM   #4
Possibly. You shouldn't have just a whole lot of play before the throttle engages. I would check any pinch points that it may be getting stuck at, how it is mounted on the engine, on the pedal, etc. A hung throttle could get you in a BAD situation...
Old 09-25-2012, 12:38 PM   #5
Stang.racr's Avatar
My pedal assembly was causing that problem on mine, I just sprayed a little wd40 on it
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 09-25-2012, 02:58 PM   #6
1Mustang89's Avatar
I can lift the gas pedal up toward me that's what play I mean
Old 09-25-2012, 03:00 PM   #7
How far? I can lift mine up 2 inches or so.
Old 09-25-2012, 03:22 PM   #8
1Mustang89's Avatar
It's loose idk how far exactly but I heard throttle Cables do that? After a whole
Old 09-25-2012, 04:49 PM   #9
I would take a look around and see if I could eliminate any pinch points, parts in need of lube, visibly broken parts, or mounting problems first. It's free so you might as well. If I was going to buy another cable, I would buy a Ford OE one.
Old 09-25-2012, 06:44 PM   #10
1Mustang89's Avatar
Ok cool thanks a lot
Old 09-26-2012, 05:05 AM   #11
No problem man. Keep us posted on what you find out. It might help someone who's having the same problem :good
Old 09-29-2012, 03:33 PM   #12
1Mustang89's Avatar
Ok so the nob on the throttle cable is loose I can push it back and fourth
New member with electrical & idle problems Kevin8677 New Member Introductions & Greetings 1 01-17-2012 07:53 PM
Idle problems BigB227 1996-2004 Mustang GT 5 12-06-2011 10:57 PM
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 08:44 PM
Idle problems need some help stangrunner 1979-1995 Mustang GT 6 09-16-2011 07:49 PM
Y2k v6 idle problems 6Banger2000 2005-2010 V6 Mustang 4 07-22-2011 07:10 AM
06:42 AM
