Finally got my car to the dyno! And burning oil help please - Mustang Evolution
Old 09-25-2012, 11:58 AM   #1
MC770's Avatar
Finally got my car to a dyno and it put out 312hp to the wheels and i forgot the torque numbers hahaha but 312hp is plenty good for me .... Only problem is now I have to run it on premium fuel which is currently over $4 a gallon in NC
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 09-25-2012, 12:00 PM   #2
MC770's Avatar
Also the engine is burning a bit of oil, like I just had to put 2 quarts in the freaking engine... any ideas on what this could be? Some of the people I've talked to have said maybe the PCV valve?
Old 09-25-2012, 12:15 PM   #3
Forum Car Trader
90GTNovi2000's Avatar
Let's hope pcv valve!! If not may be rebuild time for the heads or bottom end
90GTNovi2000 is offline   Reply With Quote
Old 09-25-2012, 12:18 PM   #4
maldog's Avatar
Region: Nevada
Join the mod crowd of premium fuel I'm paying $4.10 a gallon in Las Vegas.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 09-25-2012, 04:46 PM   #5
PVC is cheap and easy to replace. But if you see oil on the intake side of it then it maybe your problem. Also make sure it has the screen on it.
If its not that then you will need to do a compression and leak down test.
Old 09-25-2012, 05:53 PM   #6
Blown347's Avatar
4.10? Try 4.41 here in Cali for stupid 91 octane
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-25-2012, 05:58 PM   #7
Gibby's Avatar
You must be in northern Cali?..... 4.19 in the high desert for 91 : /
Gibby is offline   Reply With Quote
Old 09-25-2012, 06:42 PM   #8
Blown347's Avatar
Nope San Diego area
Old 09-25-2012, 06:46 PM   #9
Forum Car Trader
Dam 93 here is 3.99
Old 09-25-2012, 06:56 PM   #10
DaBluedude's Avatar
American gas is so fn cheap...
2003 Mach 1
Old 09-25-2012, 07:11 PM   #11
Gibby's Avatar
Nope San Diego area
You stationed at Pendleton?
Old 09-25-2012, 07:38 PM   #12
Blown347's Avatar
Yessir
Old 09-25-2012, 07:50 PM   #13
Gibby's Avatar
Yessir
Ill be at third track mon-Wednesday for work
Old 09-25-2012, 08:35 PM   #14
Blown347's Avatar
I work right across the street from there. Lol I get of leave on Tuesday morning
Old 09-25-2012, 09:02 PM   #15
Gibby's Avatar
Cool maybe I'll be able to check out the Stang.
Old 09-25-2012, 09:13 PM   #16
98StangKid's Avatar
I'm paying $3.84 for it here in Louisiana.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 09-25-2012, 09:14 PM   #17
Blown347's Avatar
I'll have it there. I'll hit u up on here like Monday.
Old 09-25-2012, 11:22 PM   #18
WhiteCobra94's Avatar
93 is $3.90-$4.16 here outside of Philly , I swapped new motor in with new HCI back in April , I has only put 230 miles on it .
Old 09-26-2012, 09:09 AM   #19
MC770's Avatar
Well I'll be able to look at it this weekend when I don't have to drive to school, and I'm praying its the PVC valve because we finally got her running good haha and yeah it's like $4.10 here which angers me because last year around this time it was $3.50 or something like that
Old 09-26-2012, 09:15 AM   #20
MC770's Avatar
Oh and I'm pretty sure I know where the PVC valve is, I'd still like to be positive, right being my Trickflow intake by the firewall right?
Old 09-26-2012, 09:16 AM   #21
Yeah. It about centered on the motor on the intake, and between the intake and firewall.
Old 09-26-2012, 12:24 PM   #22
Raht cheer...
Old 09-26-2012, 12:27 PM   #23
MC770's Avatar
Alright thanks guys, just wanted to double check myself since I don't know all that much haha
Old 09-26-2012, 12:30 PM   #24
deadsp0t's Avatar
Actually.. Gas is expensive everywhere else...
That's unimpressive
Old 09-26-2012, 12:37 PM   #25
Lorraine's driver
ab_mach1's Avatar
That's sweet! Perfect power IMO. I'd like that for my Mach. Not too much to exceed my drivetrain.
Both the foxes I had would use a quart of oil by the next oil change, even the 92 I bought new. No smoking or anything like that. Hope the PCV change does it for ya.
Instagram: @ab_mach1
Old 09-26-2012, 12:45 PM   #26
Blown347's Avatar
My beef with the 302 is every one I've ever had the rear main will seep oil. Even with a brand new one. It's usually not enough to leave on the ground but you will see the residue where the tranny meets the motor. Mine always go through oil. It's not a whole lot but its noticeable after a thousand miles or so
Old 09-26-2012, 12:48 PM   #27
MC770's Avatar
well my car leaves some on the ground, and the guy that tuned it told us that its burning oil, not a noticeable amount in the exhaust or I would've known forever ago haha
Old 09-26-2012, 12:50 PM   #28
Lorraine's driver
ab_mach1's Avatar
My white 87 had the rear main trickle. It would leave about a quarter size spot overnight.
Old 09-26-2012, 12:52 PM   #29
Lorraine's driver
ab_mach1's Avatar
Do oil separators do anything to help on the pushrod 302's? It's like a must have on the 4.6's.
Old 09-26-2012, 01:02 PM   #30
Sure, they will help remove any oil that gets past the PCV system and they are a must on forced induction engines.
Old 09-26-2012, 01:41 PM   #31
Blown347's Avatar
Damn, I don't have one lol
Old 09-26-2012, 01:44 PM   #32
Forum Car Trader
I did on my 90 and the tuner left it unhooked and breathing fresh air for some reason.
Old 09-26-2012, 07:49 PM   #33
MC770's Avatar
Alright replaced my PCV valve today and went ahead and put a new brake booster check valve in so I can have brakes when its off haha lets hope the PCV solves the burning part of my problem
Old 09-26-2012, 08:24 PM   #34
Lorraine's driver
ab_mach1's Avatar
Yup, hope so too. I can't say I really using much oil at all, but when I changed my PCV a few months ago, it was soaked in oil.
Old 09-26-2012, 08:44 PM   #35
Did you replace or check & clean the screen too?
That's what they count on to remove most of the oil to keep it from getting sucked up into the intake. That's also why I think an oil separator is a good addition. It will catch what gets past the screen and PCV valve and keep it out of your intake.
02:47 PM
