Problems with dash gauges - Mustang Evolution
Old 09-25-2012, 05:46 PM   #1
jacob.a.gasparp's Avatar
Region: Nebraska
Ok my speedometer, odometer, and tripometer, stopped working on the way to work. Apparently when that's happened before the previous owner would just hit the dash and they would all start working again but that isnt working the only thing that happens when you do the is the speedo needle jumps a little. What should I check out first do yall think and has anyone had this problem beside me?
89 gt hatchback 5.0
jacob.a.gasparp is offline   Reply With Quote
Old 09-25-2012, 05:51 PM   #2
im betting someone pulled the cluster before and didnt get everything plugged back in tight. i would pull it out(just a little bit) and check everything.
Old 09-25-2012, 05:59 PM   #3
sally2002's Avatar
Agreed sounds like a loose connection or wire problem
sally2002 is offline   Reply With Quote
Old 09-25-2012, 07:45 PM   #4
Region: Nebraska
Alright I will try that
Old 09-26-2012, 01:42 PM   #5
Region: Nebraska
Well I pulled the instrument cluster forward and didn't really find any loose wiring or anything. Do yall think it is possible that it just finally went bad?
Old 09-26-2012, 02:11 PM   #6
93slowstang's Avatar
Yes that's a possibility.
Old 09-26-2012, 02:29 PM   #7
Region: Nebraska
Crud
Old 09-26-2012, 05:28 PM   #8
Region: Nebraska
Is there anyway to just repair the speedometer
Old 09-26-2012, 05:31 PM   #9
first chase the speedo cable from the cluster to the trans. sometimes they get damaged. if you dont see anything obvious you may just want to replace it anyways. they are about 20-25$. but before you buy one pull the cable out of the trans and pull out the speedo gear and make sure its not stripped.
Old 09-26-2012, 06:39 PM   #10
Region: Nebraska
Ok I'll check all that out
Old 09-26-2012, 06:52 PM   #11
Region: Nebraska
Does the speedo cable also run the odometer and tripometer?
Old 09-26-2012, 06:52 PM   #12
yes
Old 09-26-2012, 07:03 PM   #13
Region: Nebraska
Ok I'll definitely check that out
Old 09-27-2012, 12:27 PM   #14
Bily Pepp's Avatar
I've got the same problem with my fuel gauge, it works only when I've been driving for 10-15 mins. Or so. Also my speedometer jumps until it gets to 20 then evens out, when I hit 60 it drops and hangs.
Bily Pepp is offline   Reply With Quote
Old 09-27-2012, 06:29 PM   #15
My speedo used to stick or jump till 20 and I just had to replace and grease the speedo some to smooth it out.
86.5ptOh is offline   Reply With Quote
Old 09-27-2012, 07:24 PM   #16
Robbiemustang96's Avatar
my tach stays at 2500 all the time and i dont know whats wrong with it
Robbiemustang96 is offline   Reply With Quote
Old 09-29-2012, 10:40 PM   #17
Odub421's Avatar
I had the same problem with the tach in my 92 LX. I bought a replacement OEM tach and installed it myself. It works great now.
Odub421 is offline   Reply With Quote
Very Nice Upgraded Vortech V1 S-Trim Kit (FULL KIT!! EVERYITHING)+ GAUGES AND PODS CodyNelson Mustang Parts for Sale and Wanted 16 09-30-2012 08:06 AM
LED Dash upgrade jroth823 Classic Mustangs 17 02-29-2012 06:38 AM
Triple pillar gauges RVAStang05 Mustang Paint, Appearance & Detailing 6 02-19-2012 06:08 AM
bugging out dashboard/battery light help! electrical problems ponyobsessed Pre-2005 V6 Mustang 0 01-20-2012 12:09 AM
speedo and gauges problems kirpy 2005-2010 V6 Mustang 0 10-20-2011 06:36 PM
05:54 PM
