Coolant expansion needs relocating - Mustang Evolution
Old 09-25-2012, 06:20 PM   #1
BigTone's Avatar
Alright so I just installed MM dual Eletric fans, they are enclosed in an aluminum shroud that fits flush to radiator, the problem is with the shroud the coolant expansion tank has no where to sit so i have to either relocate or find a smaller expansion tank. Idk if anyone has dealt with this problem and has advice or if any one has any smart ideas
BigTone is offline   Reply With Quote
Old 09-25-2012, 06:28 PM   #2
i have dealt with this. but my setup is probably different. i boughht a tank off summit racing for like 6$. but i dont think you will be able to put yours in the same location because your cai/intake.
its hard to see in this picture, but its at the bottom left, right next to the msd box.
Old 09-25-2012, 06:32 PM   #3
BigTone's Avatar
Yea my cai would interfere, is there a minimum size volume wise that the tank should be do u know?
Old 09-25-2012, 06:34 PM   #4
not sure. the main thing is that is will catch the overflow. so you can get away with smaller than stock size. i believe i have seen people mount smaller sized ones on the frame rail by the battery.
Old 09-25-2012, 06:45 PM   #5
BigTone's Avatar
Yea that's what I was thinking about doing, my stock tank has an outlet for pressure to escape but iv seen aluminum tanks that are completely sealed off, if I get an airtight tank should I just drill a hole on the top for pressure to get out?
Old 09-25-2012, 06:48 PM   #6
not sure bud......
Old 09-25-2012, 06:54 PM   #7
BigTone's Avatar
Lol right appreciate the help pal
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
Alright**^
Old 09-25-2012, 07:09 PM   #8
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
What about in between the fender and inner fender on the drivers side? I actually just have a bottle sitting there with the overflow tube running down into it. I need to get an actual overflow tank and mount it there
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 09-25-2012, 07:35 PM   #9
89 coupe's Avatar
I put on a half moon tank on the drivers side of the radiator if you want better photos I'll post them tomorrow.
89 coupe is offline   Reply With Quote
Old 09-25-2012, 07:46 PM   #10
BigTone's Avatar
Yea I have the half moon too but with the dual fan and shroud it doesn't fit in between the driver side fan and battery
---------- Post added at 09:46 PM ---------- Previous post was at 09:45 PM ----------
Do you mean we're the cai goes just on the opposite side of the car?
Old 09-25-2012, 07:53 PM   #11
BigTone's Avatar
Coupe if u have time to take a direct pic I'd like to see how u have it set up
Old 09-25-2012, 07:56 PM   #12
Pete Jones
no, down towards the ground almost right behind the front bumper. Should be an open space where you can see in between the inner and putter fender.
90 LX hatchback
89 LX Notchback
Old 09-25-2012, 08:10 PM   #13
BigTone's Avatar
90 i see what your saying, ill check that out in the morning thanks.
Old 09-26-2012, 11:13 AM   #14
89 coupe's Avatar
Sure thing when I get home.
Old 09-26-2012, 05:38 PM   #15
89 coupe's Avatar
Is these ok, if ya need anything else let me know.
ID:	70175   Click image for larger version
Old 09-26-2012, 11:22 PM   #16
BigTone's Avatar
I see what u did, my second fan is set further left then yours is though, so there Barley any space between the fan an the bat. In going to see if I can work something out tomorow, thanks for the help guys
01:38 AM
