Timing Advance Recommendations? - Mustang Evolution
Old 09-27-2012, 11:27 AM   #1
Ohdang1990's Avatar
I think my timing is off a little and just wondering what you guys think I should set it to with my current setup. It's a boss block with gt40 aluminum heads, gt40 upper and lower intake and 30lb injectors
Ohdang1990 is offline   Reply With Quote
Old 09-27-2012, 11:35 AM   #2
Ohdang1990's Avatar
E303 cam
Old 09-28-2012, 11:33 AM   #3
Run as much advance as you can without it detonating.Usually 12-14 degrees advance, but some can go as high as 16-18 degrees.
Old 09-29-2012, 04:20 PM   #4
Ohdang1990's Avatar
What would you recommend my plug gap to be for the advance? I'm also having an issue with idle. If its still warm when I start it the idle will bounce up and down really bad and I have to wait about a minute for it to even itself out. If I try to do anything before that it will die.
Old 09-29-2012, 10:45 PM   #5
.052
Old 09-30-2012, 11:29 AM   #6
Check and clean your IAC (Idle Air Control) valve.
Check the IAT (Intake Air Temperature) sensor and ensure it is working.
94 Mustang timing question workmail21 1979-1995 Mustang GT 5 09-20-2012 03:23 PM
Timing Advance? Nashgizam 1979-1995 Mustang GT 22 01-29-2012 02:48 PM
Timing Chefnick 1979-1995 Mustang GT 2 11-20-2011 08:55 PM
Timing advance jwhayne0001 1979-1995 Mustang GT 25 11-09-2011 06:55 PM
Need help with timing cover bolts WhiteCobra94 1979-1995 Mustang GT 33 08-11-2011 03:23 PM
01:55 PM
