No more 5th gear!! WTH! Help! - Mustang Evolution
Old 09-27-2012, 10:00 PM   #1
sam13708's Avatar
Region: Oregon
so i was on the freeway tonight and I went to shift into 5th gear... and ummm there was no 5th gear.. 8o!! I just recently installed a Pro 5.0 short throw so I'm gonna pull it apart tomorrow and see if maybe I did something wrong but all the other gears feel great... 8o
sam13708 is offline   Reply With Quote
Old 09-27-2012, 10:22 PM   #2
Maybe you set the stops to tight and it is not going completely into 5th gear?
Old 09-27-2012, 11:03 PM   #3
sam13708's Avatar
Region: Oregon
just tried moving the stop, it's def not that. which really sucks..
Old 09-28-2012, 08:26 AM   #4
Time for a rebuild or replacement.
Old 09-28-2012, 12:50 PM   #5
sam13708's Avatar
Region: Oregon
Yep, no good.
Old 09-28-2012, 01:18 PM   #6
you shouldnt use bump stops period, take them out
Old 09-28-2012, 01:30 PM   #7
Why do you think that?
Older T5's are known to need them to prevent overshifting and bending the shifting forks.
Old 09-28-2012, 01:34 PM   #8
sam13708's Avatar
Region: Oregon
Ya the stop bolts are great I think! makes he shift feel so much smoother.
Old 09-28-2012, 01:39 PM   #9
Check your shifter boot and make sure it isn't bunching up and preventing you from getting the trans into gear.
Here's a link to a Pro 5.0 Shifter Install in case you want to go over the installation and double check the install.
Old 09-28-2012, 03:34 PM   #10
I'm curious also. I don't use them as an actuall stop, but I just set mine a hair past where it goes when I shift.
Old 09-28-2012, 03:38 PM   #11
That's exactly what you are supposed to do.
That way when you shift fast and hard they prevent you from putting to much pressure on the shifting forks.
I think some or maybe all of the newer transmissions have stops built in, but the older T5's do not.
Old 09-28-2012, 06:28 PM   #12
sam13708's Avatar
Region: Oregon
Ya I took everything off and it's still not doing anything in 5th. I'm screwed. :/
Old 09-28-2012, 06:31 PM   #13
yes you are.
Old 09-28-2012, 06:35 PM   #14
sam13708's Avatar
Region: Oregon
any ideas on what I can do to save some cash?
Old 09-28-2012, 06:44 PM   #15
Buy a service manual, tear it down yourself and see if it can be repaired.
That will save you a lot of labor costs at $70 or more per hour.
Old 09-28-2012, 10:41 PM   #16
sam13708's Avatar
Region: Oregon
ya ill definitely do that. I have a buddy that's going to help me.
Old 09-29-2012, 07:20 AM   #17
sam13708's Avatar
Region: Oregon
I'm over here in Roseburg, Oregon. thanks for the offer. If I need a new trans, or replacement probably be like a month or so before I can buy a new one.
Old 09-29-2012, 07:38 AM   #18
Do you need the T5 repair manual?
86.5ptOh is offline   Reply With Quote
Old 09-29-2012, 07:53 AM   #19
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Did you try putting the stock shifter back in to see if you still didn't have 5th?
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 09-29-2012, 07:59 AM   #20
maldog's Avatar
Region: Nevada
^+1
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 09-29-2012, 10:19 AM   #21
sam13708's Avatar
Region: Oregon
I could use the manual if u know where to get one. Also, bono haven't tried putting the stock shifter back on. I should try that before anything.
Old 09-29-2012, 12:33 PM   #22
I'll get my PDF file for the T5 repair manual and post it when I get back to my computer.
Old 09-29-2012, 01:06 PM   #23
sam13708's Avatar
Region: Oregon
cool thanks
Old 09-29-2012, 01:29 PM   #24
Here you go, hope this helps.
Old 09-29-2012, 06:03 PM   #25
sam13708's Avatar
Region: Oregon
thanks.
Old 09-30-2012, 08:01 AM   #26
Mike90's Avatar
My brothers T5 was acting up and he didn't have the money
to rebuild it or get a new one. He pulled it out of the car tore
it down. Took alot of pics and put it back together a few times.
Forget what he said was wrong with but it now works good
as new.
All that with no Manual?? If he can do it with out the manual
you should be able to do it with one...
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 09-30-2012, 09:33 AM   #27
sam13708's Avatar
Region: Oregon
Ya It should be fun. Only thing about taking the tranny out is in bolting the long tube headers. those are a pain.
10:48 PM
