Gt40 swap - Mustang Evolution
Old 09-29-2012, 12:50 AM   #1
Kenny laird's Avatar
Gt40 swap
I am in the process of installing ported gt 49 heads and a trick flow upper and lower intake with the e303 cam. My ? Is what size roller rockers to use
Kenny laird is offline   Reply With Quote
Old 09-29-2012, 12:59 AM   #2
93slowstang's Avatar
I would say 1.6. Also I forgot to mention that you will need to check pushrod length if you use roller rockers. The stocks will work with the stock stamped steel but may be too short for roller rockers.
Old 10-01-2012, 01:14 PM   #3
Spoke with a shop that builds mustangs today and he said with the trick flow upper and lower and gt40 heads i should not use e303 cam he says i will loose power. Acording to him the stock cam would make more power?
Old 10-01-2012, 01:17 PM   #4
I can see that being possible. I would type in your specs on camquest.com and figure out what cam would work best.
Old 10-01-2012, 01:18 PM   #5
Ya i just wanna di it right. Now that i have the trick flow topend thinkn about just get the trick flow heads. Just want to do it right and make good power
Old 10-01-2012, 01:39 PM   #6
Good idea. I had to get luxuries when I put on my trickflow heads. You may as well get the trickflow cam to.
Old 10-01-2012, 09:10 PM   #7
Gonna go with the ford racing aluminum gt40x heads. Just cant afford trickflow right now and its killn me not driving my car
Old 10-01-2012, 09:12 PM   #8
still a good choice.
Old 10-01-2012, 09:14 PM   #9
Gonna do some more research on cam its weird so many people say they love the e cam but this guy swears i will loose power. Gonna hit that website in a min see what rhey say
Old 10-01-2012, 09:15 PM   #10
thats the best thing to do. cams are very tricky. either use that site i told you or talk to a cam expert.
arent the gt40x heads still a little pricey?
Old 10-01-2012, 09:51 PM   #11
Not necessarily lose power, but it does lack on the low end a bit over the stock cam. The E cam picks up a little after 2k.
Old 10-01-2012, 09:53 PM   #12
+1, and the 170cc heads are almost the same price as the gt40x heads.
Old 10-01-2012, 09:56 PM   #13
So u are happy with the e cam then. Did u stick with stock pistons. And the heads are anout 600 but trick flow is a good deal more
---------- Post added at 09:56 PM ---------- Previous post was at 09:53 PM ----------
The 170cc heads are 549 each thats a little bit much for me right now. On a bit of a budget
Old 10-01-2012, 09:59 PM   #14
I'm happy with it, I can still burn 1st and chirp 2nd with 2.73 gears.
The gt40x heads are 550 a piece which makes the set only $50 cheaper than entry level twisted wedge heads.
Old 10-01-2012, 10:00 PM   #15
Make sure that 600$ price you saw isn't each also.
Old 10-01-2012, 10:05 PM   #16
Edelbrock has assembled Estreet heads for under 1k for the pair.
Old 10-01-2012, 10:12 PM   #17
This is the price for both heads i tought it was not a bad price even called to make sure
Old 10-01-2012, 10:16 PM   #18
Similar edelbrock pair. Should pick up about the same hp.
Old 10-01-2012, 10:17 PM   #19
i think thats because they dont have all the hardware in them?
Old 10-01-2012, 10:19 PM   #20
That's per head unless they are bare.
Old 10-01-2012, 10:22 PM   #21
Summit has them for 529 each assembled.
Old 10-01-2012, 10:36 PM   #22
Thanks guys ill figure it out slowatang did u have any clearance issues with the e cam
Old 10-01-2012, 10:51 PM   #23
No clearance issues at all. I am using stock rockers and installed the cam straight up, no advance or ******.
Old 10-07-2012, 07:40 PM   #24
So i have whole top end off and getn ready to do the swap. Thinkn about puting a new oilpump in any opinions and how much of a pain is it to do
Old 10-11-2012, 10:51 PM   #25
Getn there cant wait to drive again
Old 10-30-2012, 09:20 PM   #26
Well its done runs good havnt drove to much but sound healthy. Gt40 long block porteed and polished port matched to trick flow intake e303 cam. Pretty happy
Old 10-30-2012, 10:15 PM   #27
Videos?
Old 10-30-2012, 10:34 PM   #28
Soon wayer pump leakn gotta fix that and i will put one up soon
Old 10-30-2012, 11:08 PM   #29
Can't wait to see one.
Old 10-31-2012, 10:21 PM   #30
Does anyone know about this adjustment on the throttle positioning sensor
Old 10-31-2012, 10:33 PM   #31
Yes, here's a link for adjusting and checking it.http://www.muscularmustangs.com/tps.php
12:45 PM
