BBK 255LPH fuel pump info? - Mustang Evolution
Old 09-29-2012, 03:10 AM   #1
Swangin_Stangs's Avatar
Any info on this fuel pump?
Swangin_Stangs is offline   Reply With Quote
Old 09-29-2012, 04:13 AM   #2
93slowstang's Avatar
Here's a link to info for the 190 and 255 flow rates. http://www.autoperformanceengineerin...l/fpspecs.html
Old 09-29-2012, 12:06 PM   #3
WhiteCobra94's Avatar
For $10 more go with the 255lph your fuel pressure regular will take care of the rest !
Old 09-30-2012, 10:36 AM   #4
Mike90's Avatar
I agree with the above post. If you are putting a new one in go with
the biggest one they got. That way any future upgrades or Forced induction
you won't have to do it again....
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 09-30-2012, 11:08 AM   #5
I don't necessarily agree. That will depend on future plans. If those plans don't involve a bunch of upgrades, I don't see a need in going that large. You will be recirculating a lot of fuel and warming it up. That would cause a loss in power.
Old 09-30-2012, 12:49 PM   #6
Mike90's Avatar
I never thought about the fuel heating up, but I guess it is possible.
I had a A1000 on my 347 Strim and it was fine, when I took off
the Strim it did get hot in the summer months and would shut down.
On the other hand if the pump has to work at 80% to fuel your car,
would you not one that only had to work at 50%???
Old 09-30-2012, 12:57 PM   #7
the problem that i stated would most likely only be an issue with less fuel in the tank. it may also cause the pump to cause stalling when the tank was really really low from sucking the fuel to fast.
i dont think you really change the duty cycly of the fuel pump. its pumping fuel no matter if its going to the return or the injectors. its still pumpimg the same.
but with all that said its not really a major issue, the stuff i suggested. just something to aware of. and i dont see any of it a problem unless your running on really low fuel tank all the time.
Old 09-30-2012, 01:01 PM   #8
That's a very good point and one I worry about in my car. Although I haven't had any trouble out of my 255 yet it's still on the back of my mind.
Old 09-30-2012, 01:07 PM   #9
the amount of hp may or may not even be noticable. but when running really high timing the last thing you would want is warm fuel. i wouldnt sweat it to much though.
Old 09-30-2012, 04:59 PM   #10
LAS97GT's Avatar
My stock gt pump is too weak to get my car started cold. Sometimes more.
---Las97GT
Old 09-30-2012, 07:51 PM   #11
Filibuster
I just went with a holley 190lph and actually notice my car running stronger. I do think my f/p was a bit on the low side before I changed it.
I think what Dreamstang said are some good points. things I never really considered.
XXSTEVEO66 is offline   Reply With Quote
fuel pump info/ suggestions 87lx 1979-1995 Mustang GT 17 08-28-2012 08:35 PM
stock fuel pump OG86GT 1979-1995 Mustang GT 9 01-23-2012 07:55 PM
Fuel pump questions Matt5.0 1979-1995 Mustang GT 1 12-23-2011 03:19 AM
injectors and fuel pump CancerBoi69 Pre-2005 V6 Mustang 1 10-14-2011 07:28 AM
Bad Fuel Pump?? jal4411 1979-1995 Mustang GT 7 09-17-2011 02:32 PM
01:47 PM
