Injector size? - Mustang Evolution
Old 09-30-2012, 01:58 PM   #1
Matt95GT's Avatar
Injector size?
I Did read the article in the useful info about injectors. But that was like reading German.
Im just wanting to know roughly what size injectors I would need. I have a 95 5.0 with CAI, flowmaster X-Pipe and a cam.
Idk what size cam or what else may be done to car. Or how to check all that stuff.
I'm trying to learn all these things so excuse my ignorance.
Matt95GT is offline   Reply With Quote
Old 09-30-2012, 02:12 PM   #2
WhiteCobra94's Avatar
Here is a chart of what injectors with the horsepower your car has or future goal!
Old 09-30-2012, 03:16 PM   #3
LAS97GT's Avatar
Can't say I totally agree with your chart. But it's a start. My ink to HP rearing compared to FI scale is off. Besides I in NA. Wrong car or manufacturerer, or something
---Las97GT
Old 09-30-2012, 03:29 PM   #4
should be a good ball park for someone that doesnt know.
also op. dont forget you need matching maf for whatever size injectors you go with.
Old 09-30-2012, 05:47 PM   #5
Without knowing what else is done to the car, it is hard to say.
Whatever you have now, must be working?
Old 09-30-2012, 05:50 PM   #6
LAS97GT's Avatar
I hate iPhone, changes words by auto correct. Glad you got my meaning. The chart has ratings that are off for NA motors.
---Las97GT
Old 09-30-2012, 07:32 PM   #7
Matt95GT's Avatar
Runs fine. No sputtering or anything.
Is there a way to test the pressure on my current injectors?
And even though u do not know much about this stuff would 42 pounds be to much?
Old 09-30-2012, 07:36 PM   #8
if your mostly stock i would stick to 19 lb injectors. you wouldnt be even able to run 42 lb injectors without a new maf and 500$ tune. even then you probably would just flood out and not be able to start it. even with full hci you wouldnt need more than 30s. but i wouldnt even put 30s on yet until you have upgreaded our hci (heads cam intake).
Old 09-30-2012, 08:10 PM   #9
Matt95GT's Avatar
I have the intake and cam just don't know about the heads. I do plan getting the abaco mad though and a full tune at the beginning of next year. Guess that'll give me an idea of what my car has?
Old 09-30-2012, 08:13 PM   #10
See if you can find some numbers on the heads. Are they aluminum? What size injectors do you have now?
Old 09-30-2012, 08:16 PM   #11
Matt95GT's Avatar
I know what mean! I meant abaco MAF
Old 10-01-2012, 08:59 AM   #12
Well I don't know 100% either but from the speed shop I use and the guys that work there that showed me the chart , I can't argue it!!
I had 24lb injectors with my bored motor and HCI, the 24lb injectors were maxed out at 5000rpms so I bumped up to 30lb injectors and I can run to 7000rpms before max!
So I'm sure the chart is close but nothing is 100% untill you hook up to a dyno and see what you need!!
Old 10-01-2012, 09:49 AM   #13
Lorraine's driver
ab_mach1's Avatar
I know we already have a chart linked on here, but here's a whole PDF on injectors. Page 3 has the injector per HP chart.
http://www.fordracingparts.com/downl...d_Adaptors.pdf
Instagram: @ab_mach1
Old 10-04-2012, 08:51 PM   #14
LAS97GT's Avatar
What up AZ! Hey, sorry to go off topic, but you in a car club in NC, right? Your link is on FL web site. What do I need to join? Sry all, my private msg is full. Can't delete w/out laptop, using my phone.
---Las97GT
Old 10-04-2012, 09:20 PM   #15
LAS97GT's Avatar
Hi folks, the injector chart didn't make sense to me till I went 24 w/out FI. It's ok for NA apps, but it was really over kill to some degree. Real pros will tell you to stick with the appropriate inj size till you exceed their capability in HP, meaning more HP gain with increased fuel delivery. Example, SOHC can handle 30s an more with a supercharger, but with that bring necessary improvements to deliver the fuel. I am putting down 270+ and 19s could do the job, but I have upgrades in mind.
Best up: 24s won't increase fuel consumption, but in my opinion, best mileage is gained at higher RPMs, kinda like 4 bangers. Weird!
---------- Post added at 10:20 PM ---------- Previous post was at 10:18 PM ----------
Is this charts HP measured in RWHP? It makes sense in that arena.
---Las97GT
Old 10-04-2012, 09:24 PM   #16
McNassty's Avatar
Press and hold the message you want to delete like you would deleting an app
McNassty is offline   Reply With Quote
Old 10-04-2012, 09:41 PM   #17
McNassty's Avatar
Actually forget that I just tried it and it doesn't work. That's the way you delete messages on another forum app that I belong to and they look the same so I thought it would work, sorry
Old 10-04-2012, 10:01 PM   #18
The charts are measured for Flywheel HP
Old 10-04-2012, 11:23 PM   #19
Lorraine's driver
ab_mach1's Avatar
Actually, I'm in Indiana. I haven't joined any clubs, just cause my schedule is pretty full. Haha! I wish I was further south. It's supposed to be highs in the 50's for the next week or so. I like the cold, just not looking forward to driving my ride in the winter.
10:54 PM
