Idle Relearn Thread - Mustang Evolution
Old 09-30-2012, 04:05 PM   #1
Mike90's Avatar
Idle Relearn Thread
OK after installing my new fuel pump my idle is all
over the place. I read the thread and have a question.
It says to turn the A/C on high for a minute. My A/C is
bypassed right now because the A/C compressor froze
up. Do I still need to do this step?
Thanks, Mike
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 09-30-2012, 04:39 PM   #2
No, if you don't have one that's functional. You do that so the ECU can learn to adjust the idle for the extra load.
Old 09-30-2012, 05:00 PM   #3
Mike90's Avatar
That is what I thought but wanted to make sure.
Thanks
Old 09-30-2012, 05:02 PM   #4
93slowstang's Avatar
I would still turn lights and blower on to put a load on it.
Old 09-30-2012, 05:07 PM   #5
and crank up the bumps!
Old 09-30-2012, 06:09 PM   #6
Mike90's Avatar
You know now that you say that you may be right. My volts gauge
usually reads 14v now sits at 13v. I need to check the ground though,
when I turned the key to start, power cam on but it didn't crank. Turned
it off tryed again and fired right up, hmmm....
Old 09-30-2012, 06:14 PM   #7
Lorraine's driver
ab_mach1's Avatar
+1
Instagram: @ab_mach1
Old 09-30-2012, 06:51 PM   #8
You can also turn your steering from lock to lock,,but we always just drive it for a bit,,the idle air moves around a little while your driving too..
mymustang is offline   Reply With Quote
Old 10-01-2012, 06:51 AM   #9
Forum Car Trader
90GTNovi2000's Avatar
Everything open all doors trunk etc roll windows up and down lock to lock radio wipers lights e brake hazards etc.. Lol anything that draws power.
90GTNovi2000 is offline   Reply With Quote
Old 10-01-2012, 01:25 PM   #10
You can do all that, but an alt (unless it's a very high amp alt) kicking on won't affect the idle much. I know my stocker does not, but the 200 amp alt I'm putting on it will be a different story I'm sure, if it is heavily loaded.
03:43 AM
