Easy and cheap upgrades - Mustang Evolution
Old 09-30-2012, 09:16 PM   #1
I have a stock 1990 5.0 and I want to know what is the maximum horsepower I can get out my mustang if I have 2k to put into it. It is a manual. Any suggestions on what to get?
Caveman681 is offline   Reply With Quote
Old 09-30-2012, 09:24 PM   #2
93slowstang's Avatar
I would save up a little more and get the trickflow top end kit, or one of the other kits. Best bang for the buck IMO.
Old 09-30-2012, 10:12 PM   #3
Blown347's Avatar
Definitely a trick flow track heat or twisted wedge top end kit would be the best. For 2500ish bucks it will give you somewhere in the neighborhood of 360 hp, a huge improvement over the stock 225 hp.
But if you only have the 2 grand you could do a trick flow upper and lower intake, a set of headers, bigger throttle body, cold air intake, and I would invest in some rear end gears as well. They don't give any more hp, but te acceleration increase you get is immense for such a cheap part. All of that should be close to your 2 grand mark
---------- Post added at 09:12 PM ---------- Previous post was at 09:10 PM ----------
Oh and if you had any left I'd say an electric fan, frees up a little power and gives you a lot better cooling power for your soon to be beast
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 10-01-2012, 01:01 AM   #4
Filibuster
Agree with both above statements. A trickflow top end kit has got to be one of the best upgrades you can do to the fox.
Most people I know are running trickflow, but I also like afr. Though I believe afr to be a bit more $$$ for roughly the same performance. So bang for da buck I gotta say trickflow
XXSTEVEO66 is offline   Reply With Quote
Old 10-01-2012, 09:12 AM   #5
Blown347's Avatar
I'm all advocating trick flow and I run edelbrock heads and intake lol
---------- Post added at 08:12 AM ---------- Previous post was at 08:11 AM ----------
Which is also a great setup but I believe for just a bolt on application the trick flow kit is cheaper and gives a couple more horses
Old 10-01-2012, 10:11 AM   #6
wc3john's Avatar
On3 turbo kit... IMHO. It will retain stock driveability as well as power when you want it
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-01-2012, 12:00 PM   #7
Blown347's Avatar
That could give some power but forced induction can be a double edges sword on a stock motor. I would never put any kind of turbo or blower on t without at least a forged rotating assembly
Old 10-01-2012, 12:10 PM   #8
Lots of models had the forged pistons stock. And the crank will usually out last the block. With that said its still rough on the stock parts. It's best to upgrade.
Old 10-01-2012, 12:58 PM   #9
wc3john's Avatar
But within 2 grand worth of parts... And if he stays on 8-10 psi. It'll be fine. Provided you have a good tune!
Old 10-01-2012, 02:52 PM   #10
What gears would y'all recommend. 3.73 3.90 4.10? This car will mainly be used on a road course b
Old 10-01-2012, 02:55 PM   #11
Jeff44's Avatar
4.10's
Jeff44 is offline   Reply With Quote
Old 10-01-2012, 03:00 PM   #12
Blown347's Avatar
If ur going to drive it on te street a lot don't go any higher than 3.73s your rpms will stay consistently higher the more aggressive you go. I have 3.73s and already in 5th gear goin 65 my rpm sits around 2400
Old 10-01-2012, 04:37 PM   #13
2300turboford's Avatar
On 3 turbo kit 1500 in summit
---------- Post added at 06:37 PM ---------- Previous post was at 06:36 PM ----------
Just get some good rods
Old 10-01-2012, 05:04 PM   #14
and an upgraded turbo
JayKranz is offline   Reply With Quote
Old 10-01-2012, 05:08 PM   #15
He shouldnt the on3 comes with a 60 mm i think
Old 10-01-2012, 05:17 PM   #16
it comes with an On3 branded 70mm and I had two of them die within 300 miles on low boost.
Old 10-01-2012, 05:19 PM   #17
Let me ask u a question when u got on it when u go to turn the car off did u let it cool down ?
Old 10-01-2012, 05:25 PM   #18
Let it cool down? Spin down, yes. The second one they sent me had shaft play out of the box. $300 turbos are garbage no matter how careful you are.
Old 10-01-2012, 06:28 PM   #19
That's what I ment lol and yeah I would use the good old hx35
Old 10-01-2012, 06:49 PM   #20
Haha yeah just checking. I thought so. I like the kit but I definitely understand why the other kits are so much more $.
Old 10-02-2012, 07:30 PM   #21
WhiteCobra94's Avatar
Well if you only have 2k , your forgetting labor cost to install a turbo, save an extra $500 and get a top end kit, turbo comes last!!!! But if you don't do the top end kit yourself you still have labor cost which can be $1,000 plus
Old 10-02-2012, 07:39 PM   #22
Blown347's Avatar
But the top end kit is more then doable at home. The turbo install would require a tune which would be another 400 on top of the install
10:07 AM
