Gt40 set up problem - Mustang Evolution
Old 10-01-2012, 09:36 PM   #1
Untamed281's Avatar
Ok guys, I have a 1995 mustang gt with gt40p heads, explorer intake, TFS Stage 1 cam with 1.72rr. I try to turn it on, but it will just make a popping sound in the intake and will idle at very low rpms. It also makes a beeping sound in the passenger foot panel, where the cpu is located. What could be the problem?
2010 Mustang GT- 5MT, JLT CAI, TUNE BY BAMA, M/T DRs, stock 3.31s, 13.1 @98 mph 1.83' 5,200 LAUNCH
1995 Mustang GT- 5MT, GT40Ps, Explorer Intake, TFS 1, 3.73s NOT RUNNING
Untamed281 is offline   Reply With Quote
Old 10-01-2012, 09:58 PM   #2
93slowstang's Avatar
Assuming you're not having ptv clearance problems you may need to check your timing, and fuel pressure. What size injectors are you running?
Old 10-01-2012, 09:59 PM   #3
I have no clue about the beeping.
Old 10-02-2012, 04:09 AM   #4
Me either
Sounds like timing to me.
Old 10-02-2012, 11:02 AM   #5
Untamed281's Avatar
I'm running 24lbs injectors, and it won't give me a chance to mess with the timing. Could it be something with the tune?
Old 10-02-2012, 11:16 AM   #6
Did you unplug the spout connector with the car off, set timing, then plug back in the spout connector with the car off again?
Old 10-02-2012, 01:39 PM   #7
You can unplug the spout connector and line up the marks on the distributor base to crank it. Once it starts set the timing. My timing backed off to about 10* atdc and had similar problems.
Old 10-02-2012, 02:27 PM   #8
Watch out for pianos and safes falling from the sky . Bet it's thAt dam coyote trying to catch up
tbonestang is offline   Reply With Quote
Old 10-02-2012, 02:41 PM   #9
Untamed281's Avatar
I've tried to move the timing but with the car on, I'll try to move it with the car off after work. I'll let you all know how it goes.
02:33 PM
