351 - Mustang Evolution
Old 10-02-2012, 07:24 PM   #1
351
I have a 69 351 block I want to build a 408 stroker. When I did my 347 my machine guy said other than boring it he had to notch a piece off the block for crank clearance. I read online for a 408 the only machine work is boring does know for sure exactly what needs to be done to my block? Thanks
Dtw0519 is offline   Reply With Quote
Old 10-02-2012, 08:43 PM   #2
WhiteCobra94's Avatar
To know for sure I'd call your machine shop and have the experts tell you !!
Old 10-02-2012, 08:48 PM   #3
FortyBrandon's Avatar
Is it out of a Mach 1?
FortyBrandon is offline   Reply With Quote
Old 10-02-2012, 09:00 PM   #4
the knotch is for rod clearance.
Old 10-03-2012, 08:47 AM   #5
I don't think it was a Mach 1 I didn't pull the motor I bought it off a guy
Old 10-03-2012, 02:57 PM   #6
Called my machine shop he said he wasn't 100 percent sure about the 351 so I guess if I put it together and something's hits I'll know the answer
Old 10-10-2012, 03:15 PM   #7
The 351W and 302 blocks are different. You may or may not need to notch the 351W block for the 408.
You need at least .080" clearance on all rotating parts to allow for heat expansion of the components.
07:02 AM
