Wierd engine light - Mustang Evolution
Old 10-03-2012, 08:57 AM   #1
Adogg's Avatar
Wierd engine light
So Iam driving today and Iam at a stop then I get going an my engine light comes on. I make another stop an the light goes away and I get going and it happens again this happened a few Times then stopped Iam thinking its my TB? Could I be right? And if so how do I clean it ?
---------- Post added at 08:57 AM ---------- Previous post was at 08:53 AM ----------
Also I have an o/r h pipe(no cats) but this code just started happening and I have had the exhaust for a long time
Don't hate....... appreciate
Old 10-03-2012, 02:22 PM   #2
maldog's Avatar
Region: Nevada
Have the codes read!
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 10-03-2012, 02:23 PM   #3
Mustang936's Avatar
+1
Mustang936 is offline   Reply With Quote
Old 10-03-2012, 02:27 PM   #4
Adogg's Avatar
It's a 94 it is obd1 so it is a lot harder to
Pull codes
Old 10-03-2012, 02:34 PM   #5
maldog's Avatar
Region: Nevada
Pull codes
I know it's hard. I had a older car with the obd1. If you search the Internet you can actually use a wire and jump the plug and read the flashes and that will tell you your code you can look up.
Old 10-03-2012, 03:03 PM   #6
Adogg's Avatar
Each car is different on reading there codes were can u get tb cleaner and how does it work?
Old 10-03-2012, 03:55 PM   #7
reading the codes arent that hard. i dont remember the procedure, but its probably in the stickies section. it only takes a few minutes to check. also i have seen guys pick up obd1 scanners for around 25$ if you dont wanna mess with a jumper wire. this would be way better than guessing.
but also it never hurts to clean the tb.
Old 10-03-2012, 11:06 PM   #8
Slow5.0's Avatar
AutoZone sells em for around $30 or less I believe. Obd1 scanners are a pain in the *** cause you gotta keep track of beeps and tones. Not too fun to be quite honest.
Slow5.0 is offline   Reply With Quote
Old 10-04-2012, 05:21 AM   #9
wc3john's Avatar
Tb and intake cleaner = seafoam... Some good stuff
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-04-2012, 07:23 AM   #10
What are u talking about I have one and it gives u the code . Was 15 bucks on the net. Comes with. Booklet of what all the codes mean. Shows u codes for stuff that not bad enough to trigger cel
tbonestang is offline   Reply With Quote
Old 10-04-2012, 08:25 AM   #11
Adogg's Avatar
Most likely that is the obd2 scanner what year is your car?
» Members Mustangs
2004 Ford
04_GT
GT
Buster
Add your Mustang
03:53 PM
