Oil Pan Replacement? - Mustang Evolution
Old 10-05-2012, 12:49 PM   #1
MC770's Avatar
Well I finally found the exact cause of the leak in my car... The damn oil pan... I have attached a picture with the two leak spots circled, my question is what is a good replacement pan and the best way to get the old one out.. I know some cars you can drop the k-member or pull the engine which one is easier with this car? if you have a choice that is haha
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 10-05-2012, 12:54 PM   #2
Filibuster
If it's only leaking from the drain plug and oil level sensor then they can be fixed easily without messing with the pan.
XXSTEVEO66 is offline   Reply With Quote
Old 10-05-2012, 03:58 PM   #3
I like my Canton 7 qt. pan. The extra capacity is always a good idea and the internal baffles keep the oil where it needs to be.
To remove the pan, I think you can just unbolt and lift the engine from above to get enough room to R&R the pans.
Are the threads damaged on your old pan or is it leaking around the inserts? Just thinking that maybe tapping out the threads would be easier than replacing the whole pan.
Old 10-05-2012, 05:39 PM   #4
I agree. And if the thread aren't bad, maybe just some liquid Teflon will do the trick.
Old 10-05-2012, 06:57 PM   #5
Filibuster
Also yes you can just unbolt the motor mounts and lift the engine. You will have to unbolt the oil pump pickup tube to sneak the pan over the cross member. But I also did this with my trans out of the way. So im not to sure how much you can lift the eng with the trans in?..
Old 10-06-2012, 03:18 PM   #6
MC770's Avatar
We'll I'll take some time to try and figure out if I can fix those areas without having to remove the pan... If not I'm just going to get a new better pan if I have to take it out anyways haha
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
OEM Factory OIL in the '13 GT - HELP!! Greg3 2011-2014 Mustang GT 5 06-02-2012 05:33 PM
Dropping oil pan Taxman 1979-1995 Mustang GT 9 04-04-2012 02:21 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
03:12 PM
