Floor Pan Replacement - Mustang Evolution
Old 10-06-2012, 11:01 AM   #1
Jeff44's Avatar
How difficult is it to change out the floor pans on an 87 gt convert.
Jeff44 is offline   Reply With Quote
Old 10-06-2012, 11:06 AM   #2
Not to bad. I did the passenger side I'm my 88. I even used one I cut out myself from the boneyard.
After I retrieved the piece from the junkyard:
I set it in place over the existing to figure out where it goes..
Then I cut the opening a little small so the they overlap just a bit. I then riveted them together pretty good to hold it in place. Then I welded the dog snot out of it. Then I used some silicon on any spots that looked like they could leak.
Just Becareful when cutting or drilling to watch out for fuel and brake lines.
I also primed and painted any bare metal to prevent rust.
I'm mot sure if the procedure is the best or is different when using a full brand new pan. But it worked great for me and you can't even tell.
Old 10-06-2012, 01:54 PM   #3
Jeff44's Avatar
Wow! Thanks for the info. I don't know whether I am going to buy them New or see if I can find them used. Still up in the air.
Oil Pan Replacement? MC770 1979-1995 Mustang GT 5 10-06-2012 03:18 PM
L.E.D. Replacement Bulb 99ford FYI Ads | Recently Listed 29 09-13-2012 08:13 PM
TOB replacement runvsofthisbull 1996-2004 Mustang GT 2 07-20-2012 04:56 PM
My Side Mirror Broke Off and Now I Need Advice Regarding Replacement JimHyde 1996-2004 Mustang GT 3 12-03-2011 08:16 PM
2001 V6 coupe exhaust replacement Youngblood Pre-2005 V6 Mustang 8 10-18-2011 05:17 PM
12:24 PM
