AFR's on the way what's everyone's favorite intake? - Page 2 - Mustang Evolution
Old 10-13-2012, 11:43 PM   #36
have you seen my fabricated aluminum v covers? look in my albums if you need to. but usually these kind are at least 150$+. i got these brand new for 80$ from a place called kmj performance. they are a ebay site, but they have a regular warehouse/store. they dont have great reviews for some of there china type stuff. but i couldnt find anything bad about the covers. but they look sick. they are also taller than stock to clear the rr's. but you may need a spacer to clear them but not sure. but you would for any taller covers somthat wont change with other ones. if you want i can post a pic tomorow?
Old 10-13-2012, 11:47 PM   #37
Cool, I'll check them out.
---------- Post added at 12:47 AM ---------- Previous post was at 12:44 AM ----------
I do have a 3/8 spacer with my new intake. Would that be enough clearance?
JayKranz is offline   Reply With Quote
Old 10-14-2012, 12:03 AM   #38
I cam measure tomorrow for you. Shoot me a pm in the afternoon so I don't forget. I still have a set of stockers I can compare them to. But it may work because that's prolly close to how much they are taller
Old 10-14-2012, 08:23 AM   #39
Originally Posted by JayKranz View Post
Now I need valve covers. Any thoughts on which ones are "cool"?
I like the fabbed covers too, but what I really want is a tall set of the black with red writing Ford valve covers. I settled for a set of ball milled covers from KMJ, KMC, Skip White or one of those eBay cheap parts places. They were only $50-$60 at the time.
To clear the tall valve covers it usually requires a 1" spacer for most of the EFI intakes.
Old 10-14-2012, 08:42 AM   #40
Would I need the tall valve covers?
Old 10-14-2012, 08:59 AM   #41
With RR's you probably will to keep them from hitting the top.
Once you have the heads on and rockers installed you can put some play doh on a rocker and roll the engine over 4 revolutions to determine how much clearance you do or do not have. I think .080" is recommended on most engine parts to allow for growth from heat expansion.
Old 10-14-2012, 09:11 AM   #42
Okay, thanks
Old 10-14-2012, 11:13 AM   #43
What about gaskets? I was going to stick with the trusty old FelPro 9333's since my compression will be low anyways. Anyone see an issue with that? I kind of like the idea of not having an indestructible gasket that forces me to bend a rod before blowing the gasket. Thoughts?
Old 10-14-2012, 12:00 PM   #44
I'm not sure if they are rated for that or not, but I don't think they are. Will see what trojan says though.
Old 10-14-2012, 12:03 PM   #45
I just checked the AFR site and they actually have recommendations for all the gaskets. No need for me to think too hard on that one.
Old 10-14-2012, 12:24 PM   #46
Perfect. Best to use what they recommend. Does it also say for forced induction applications?
Old 10-14-2012, 12:24 PM   #47
Yep
Old 10-14-2012, 12:25 PM   #48
Yep
Sweet.
Old 10-14-2012, 12:27 PM   #49
It also has a dyno sheet for my exact engine with my exact heads (carbed) rather than efi like my set up. Either way they made 453 HP, so I'm gonna have a hard time staying around 500 with my turbo. This is going to cause problems. Maybe I should think about this. Different direction maybe?
---------- Post added at 01:27 PM ---------- Previous post was at 01:26 PM ----------
You don't want to weld a bunch of steel under my car next Spring do you? I'm gonna end up with a pretzel
---------- Post added at 01:27 PM ---------- Previous post was at 01:27 PM ----------
A fast, stock looking pretzel.
Old 10-14-2012, 12:28 PM   #50
I say best to use what they want. But if you want a great gasket. Trojan recently found a Mr gasket brand MLS gasket that doesn't require a specific ra finish like the other ones do. But I can't review them by experience cause I don't have any with them.
Old 10-14-2012, 12:29 PM   #51
Okay, I'll check them out, but my block is new and my heads have been milled so I'd probably be good.
Old 10-14-2012, 12:29 PM   #52
You looking for some "dreamstangs custom connectors"? Lol
Old 10-14-2012, 12:30 PM   #53
Haha, I think I might be
Old 10-14-2012, 12:33 PM   #54
If you need information on the gasket I'm talking about. It should be a very recent post on my thread "what it takes for forced induction and much more" it shouldn't be to far down in this section.
Old 10-14-2012, 12:33 PM   #55
I'll check
Old 10-14-2012, 01:01 PM   #56
I liked what I saw of the Mr Gasket MLS, as to how well it works I don't know yet, but I intend on trying a set when I pull (supervise pulling I should say) the heads to install the Valley Girdle Pro.
P.S. Problems with too much HP is a good problem to have IMO.
With the HP mine makes now the formula says that around 8 psi of boost I should hit the 600 HP range. If it does and stays together it's going to be a carnival ride until I figure out how to stick it to the pavement. My wife is gonna shoot me for sure.
Old 10-14-2012, 01:01 PM   #57
Ditto
Old 10-14-2012, 01:03 PM   #58
dont worry, she wont unload the whole clip. she needs some left for when project 408 goes down.
Old 10-14-2012, 01:08 PM   #59
Yeah, she hasn't even heard about that one just yet.
I tell you though with what I have spent on her and for her lately she should be pretty mellow for a while. She's a great woman and she has stuck with me through all of my hard drinking, bad temper and fighting days, so I have to treat her right and do for her whatever I can, whenever I can.
Old 10-14-2012, 01:11 PM   #60
exactly! sounds like you got a great woman!
Old 10-14-2012, 01:18 PM   #61
Yep, we've been married since we were 17 and people around here said it would never last and it was a BAM.
To them, they were wrong.
Old 10-14-2012, 01:24 PM   #62
Nice, congrats!
Old 10-14-2012, 02:12 PM   #63
rwsmith3623's Avatar
Intake showed up two days ago and AFR's came today. If only I had a garage
Awesome. These heads don't even look used!
rwsmith3623 is offline   Reply With Quote
Old 10-14-2012, 02:20 PM   #64
wc3john's Avatar
Can't you always just run lower boost out of the turbo? Like maybe only spool to like 4 lbs?
I don't know it sounds like it'd be possible to me
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-14-2012, 02:24 PM   #65
Correct me if I'm wrong, but aren't some turbos 'too big' to only spool to 4lbs?
Old 10-14-2012, 02:26 PM   #66
depends on the spring in the bov. but if you could get the right one i dont see why not. his plans he was talking about are already with low boost though.
Old 10-14-2012, 02:29 PM   #67
wc3john's Avatar
I don't know much of anything about turbos so that's why I threw the question out there. And if he wants to stay at a given horsepower, I would think that you could just go lower on the boost. Quicker spool, easier on the block, less fuel... But I'm just talking out of my ***. I don't know much about turbos regardless lol
Old 10-14-2012, 02:29 PM   #68
makes sense. I guess I've just never seen anyone run 4lbs other than the tiny little turbos on the neon srt's and the vw's etc. I had always assumed a turbo of a certain size could only spool so low, just like turbos can only spool up to so much boost.
Old 10-14-2012, 02:37 PM   #69
well the turbo would still spool the same but the boost would exit through the bov. but who knows? maybe you cant even get a spring that small for certain size turbos.
Old 10-14-2012, 02:41 PM   #70
Just got back. The problem is that the new motor is going to be pretty efficient I think. 3-5 lbs max is probaly what I'll be able to run due to the block limits. That could add anywhere from 50-150hp for all I know. On my crappy old stock motor with stock everything and a Chinese turbo, I got about a 15hp to the wheels gain per lb of boost. Now I have an awesome motor and and awesome turbo. I'm gonna end up with a lot more power than I planned. No big deal it just means I'll be doing this all again in a year or whenever I split the block and then I'll get a boss or a Dart and I'll go for 700hp
05:53 PM
