AFR's on the way what's everyone's favorite intake? - Mustang Evolution
Old 10-08-2012, 09:50 AM   #1
This is for a 331 turbo car. Going to run low boost. I'm actually "trying" not to go above 475 at the wheels. Seriously
JayKranz is offline   Reply With Quote
Old 10-08-2012, 10:16 AM   #2
I really am leaning towards a GT40 Tubular.
Old 10-08-2012, 11:22 AM   #3
Gt40 tubular is a good intake. But the cobra I.take flows pretty similar and can be ported down the road if you want. But personally I'm a fan of trickflow. Either way the gt40 will suit your needs and looks cool to.
Oh btw congrats man. I can't wait to here that your safely on the road again! Did you get the big combustion chamber afrs?
Old 10-08-2012, 11:26 AM   #4
Yep, I got a set of "used" 185's with the 72cc, perfect for what I need. My engine will make block splitting power regardless of intake so maybe I should just go for cool
Old 10-08-2012, 03:30 PM   #5
rwsmith3623's Avatar
I run a set of 205 afr's and ill never run a different head combo. I've never had anything but amazing results with those heads
rwsmith3623 is offline   Reply With Quote
Old 10-08-2012, 03:45 PM   #6
Awesome, thanks for the confirmation.
---------- Post added at 04:45 PM ---------- Previous post was at 04:43 PM ----------
I'm about to order an Edelbrock Performer RPM II intake now as well. I almost have everything I need.
Old 10-08-2012, 04:24 PM   #7
WhiteCobra94's Avatar
GT40 tubular , HolleySystem Max II, Edelbrock RPM II
Old 10-08-2012, 04:54 PM   #8
I went with the new RPM II.
Old 10-08-2012, 04:55 PM   #9
Sweet.. now we will be expecting a video clip..
Old 10-08-2012, 04:56 PM   #10
Video to follow closer to Spring. I don't have a garage
Old 10-08-2012, 05:00 PM   #11
2300turboford's Avatar
Those make 95 hp over gt40p heads
Old 10-08-2012, 05:02 PM   #12
On a stock motor at that. Maybe more on a boosted 331
Old 10-08-2012, 05:31 PM   #13
Yeah, my tuner told me I'm going to have a hard time keeping it under 450, but I will try. I don't have supporting trans and sub frame hardware to comfortably go much over that.
Old 10-08-2012, 09:48 PM   #14
My choices for your build would be the Edelbrock Performer RPM II , or the Holley Systemax. I believe I read a while back that they are both close in flow and HP gains. Don't quote me on that though, I read so much that sometimes I get things confused.
I considered both for my engine, but ended up going with the Victor because I got a really good deal on it and it will support more HP down the road. Now I'm on the fence about keeping my Edelbrock RPM heads or selling them and getting a pair of Victor heads. Decisions, decisions.
Old 10-12-2012, 01:09 PM   #15
Intake showed up two days ago and AFR's came today. If only I had a garage
Old 10-12-2012, 01:13 PM   #16
Attachment 72016
Nice!
You're going to have to build you a garage so you can tinker with your toy year round.
Old 10-12-2012, 01:17 PM   #17
I know! For now I need someone near Chicago to build my engine. Any takers?
Old 10-12-2012, 01:37 PM   #18
Dammit, I'm in Central MO, not that far away. I wish I had full use of my arms, back and hands. I could do that for you if I did.
Old 10-12-2012, 01:40 PM   #19
Ditto, not too far. I don't have a space to do it anymore since August.
Old 10-12-2012, 01:46 PM   #20
Do you think my 42lb injectors are good for 450-500hp? I can buy new ones but these only have maybe 300 miles on them.
Old 10-12-2012, 01:48 PM   #21
Yeah, sadly I know how things go sometimes.
I really do wish I could help you with it, I wouldn't even charge for it to help a friend out.
Old 10-12-2012, 01:50 PM   #22
I may try and rent a space, but it would most likely be easier/cheaper to just hire it out.
Old 10-12-2012, 01:54 PM   #23
Ok, I found the injector sizing calculator I was looking for - RC Fuel Injection
It appears that the 42's will be pretty much maxed out at 450 HP, but they should serve for you to get it up and running ok. Then if you find out you need more after a good tuning you can replace them with some larger ones.
I have a new set of Siemens 60 lb. I'm going to use in my engine. If you get in a spot and need some I can loan them to you or we can work out something. I won't need them for a little while anyways.
Old 10-12-2012, 01:56 PM   #24
Okay sounds good. I may just take the plunge and get some while the engines apart.
Old 10-12-2012, 02:16 PM   #25
I'm about 2 hours away, but I would love to help if I wasn't working so much. If you can't find anywhere close let me know.
Old 10-12-2012, 02:18 PM   #26
Cool thanks
Old 10-12-2012, 05:05 PM   #27
Billymich's Avatar
I have a buddy who has access to the naval base and bay time there is suuuuuper cheap, maybe the next time Im in chicago we can work on our cars together.
Old 10-12-2012, 05:32 PM   #28
That might work, thanks.
---------- Post added at 06:32 PM ---------- Previous post was at 06:31 PM ----------
You're talking about Great Lakes I assume.
Old 10-13-2012, 06:57 AM   #29
Just picked up a set of these with locks used with dyno time.
http://www.summitracing.com/parts/CCA-1631-16/
Old 10-13-2012, 09:11 AM   #30
Billymich's Avatar
Yup, Im about to tear apart the top of my block, wish me luck, kinda pressed for time
Old 10-13-2012, 09:24 AM   #31
Yeah, good luck. Don't rush.
Old 10-13-2012, 01:55 PM   #32
Great find. Those are lighter at the tip than aluminum and much stronger too.
Old 10-13-2012, 01:57 PM   #33
I paid $185 shipped with the locks. They look brand new.
Old 10-13-2012, 02:26 PM   #34
That was a bargain!
Old 10-13-2012, 11:19 PM   #35
Now I need valve covers. Any thoughts on which ones are "cool"?
06:02 PM
