Motor mounts - Mustang Evolution
Old 10-08-2012, 12:07 PM   #1
Finchms's Avatar
Motor mounts
Anyone know if for a fact that convertible mounts are a little lower than the gt mounts? I can't get the hood i want now but im also tryin to keep from cutting my factory hood. Thanks for any and all help!
Finchms is offline   Reply With Quote
Old 10-08-2012, 02:38 PM   #2
Yes they are lower. I don't remember exactly but I think it 1" but it could be a 1/2".
Old 10-08-2012, 02:40 PM   #3
Finchms's Avatar
Good! I believe everything will clear with a 1/2" but 1" would be even better! Thanks man
Old 10-08-2012, 02:42 PM   #4
Your welcome.
Old 10-08-2012, 02:53 PM   #5
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Solid motor mounts are also shorter than factory mounts
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-08-2012, 04:09 PM   #6
jdavis96gt's Avatar
Region: West Virgina
What's better solid mounts or poly? Im going to need some shortly, so I'm curious.
Old 10-08-2012, 04:22 PM   #7
WhiteCobra94's Avatar
Poly but I know my poly mounts were 1/2 inch higher then my stock ones
Old 10-08-2012, 05:27 PM   #8
jdavis96gt's Avatar
Are they squeaky?
Old 10-08-2012, 06:21 PM   #9
Not that I have noticed, I've put 300 miles on my car nice my motor swap I havent heard anything !!
Old 10-08-2012, 06:30 PM   #10
Pete Jones
I do have a brand new set of polys I traded a pair of solid mounts for to a buddy. He has the Ssi intake and was trying to fit it under his stock hood, the solids did lower his engine more but still not enough to clear his stock hood.
90 LX hatchback
89 LX Notchback
Old 10-08-2012, 06:33 PM   #11
With my poly mounts , edelbrock performer 5.0 intake and 1in intake spacer my engine sits just under 4 inches higher then stock, I svo hood only clears by 1/4 inch
Old 10-08-2012, 06:40 PM   #12
Pete Jones
Also forgot to mention he had a tubular k member, don't know the brand but they may also have contributed to the hood clearance issue
I run the Bbk Ssi-R intake an a stock hood won't fit on my car, the blow by tube on the TB hits the underside of my hood
90 LX hatchback
89 LX Notchback
Old 10-08-2012, 10:00 PM   #13
You have to be careful using solid mounts. They are best suited to a properly set up race only car.
There is no give to them at all and broken engine blocks and busted transmissions can occur if you make a lot of power and the car hooks up hard.
For most street/strip purposes the poly mounts are a better choice and they are much tougher than the factory rubber mounts.
Old 10-09-2012, 05:27 AM   #14
Finchms's Avatar
Success! Hood fits!
Old 10-09-2012, 05:31 AM   #15
Originally Posted by Finchms
Success! Hood fits!
Sweet. You used the convertible mounts?
Old 10-09-2012, 05:37 AM   #16
jdavis96gt's Avatar
Thanks Trojan for clearing things up for me. Much appreciated
Old 10-09-2012, 05:42 AM   #17
Finchms's Avatar
Yep. There is about a 1" difference in the gt and convertible.
Old 10-09-2012, 09:34 AM   #18
You're Welcome & Good Luck with your project.
09:16 AM
