headers/cam/intake - Mustang Evolution
Old 10-08-2012, 07:39 PM   #1
blackGT91's Avatar
headers/cam/intake
I'm putting in a E303 cam, gt40x heads and bbk shorty equal length headers. My question is do I need to Chang out the fuel system and how much HP will just this combo give me????
blackGT91 is offline   Reply With Quote
Old 10-08-2012, 09:27 PM   #2
93slowstang's Avatar
Yes, you will need a minimum of 24# injectors with matching maf. Hard to determine any gains without knowing any other mods.
Old 10-08-2012, 09:35 PM   #3
+1
I would WAG 250 to maybe 300 HP max if you use the correct MAF, injectors, & TB. Maybe on the low side of that if you still have the stock intake.
Old 10-08-2012, 09:46 PM   #4
blackGT91's Avatar
Trick flow Street burner intake, bbk 75mm throttle. Any recommendation on the MAF?
Old 10-08-2012, 09:49 PM   #5
I'm sure Trojan will agree, go with the abaco maf, it's programmable for any combination and more accurate than most other units.
Old 10-08-2012, 09:51 PM   #6
Yup, take a look at it and read about it here -> ABACO MAF
Old 10-09-2012, 06:45 AM   #7
04machazblue's Avatar
I had the same set up with 30#s and I was going 12.7 pretty steady prolly could have done better but sold it ur prolly gonna get around 280ish the gt40x flow okay but tricks flow a lot better
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
10:27 AM
