Power steering??? - Mustang Evolution
Old 10-10-2012, 12:19 PM   #1
Jbeas50's Avatar
Power steering???
How can I get rid of power steering noise even when it has fluids the noise is super loud form a 1-10 I say 8 or 9 how can I get rid of the noise??
Jbeas50 is offline   Reply With Quote
Old 10-10-2012, 01:09 PM   #2
havhammer's Avatar
Change the power steering pump or make sure its not a belt noise.
havhammer is offline   Reply With Quote
Old 10-10-2012, 01:14 PM   #3
I have the same problem even after replacing the pump. Steering rack?
JayKranz is offline   Reply With Quote
Old 10-10-2012, 01:21 PM   #4
havhammer's Avatar
How is the effort when turning?
Old 10-10-2012, 01:22 PM   #5
On mine it turns fine just loud.
Old 10-10-2012, 01:26 PM   #6
havhammer's Avatar
Does it sound like a belt noise? If so check the belt for glazing or cracking and make sure your tensioner is putting enough tension on the belt to keep it from slipping. What kind of noise is it?
Old 10-10-2012, 01:30 PM   #7
I don't have a tensioner anymore and it's a new belt as well. Can it make noise if there is fluid blockage in the rack?
Old 10-10-2012, 02:00 PM   #8
havhammer's Avatar
Generally you would feel that when turning because it would be hard to turn.
Old 10-10-2012, 02:18 PM   #9
A power steering pump will "squall" when it is getting worn out, or if it had been rebuilt and they did not get the "slippers" back in the same position as they came out (see pic) it will make noise.
The "slippers" will go back in in either direction, so I always mark the tops of mine in order to ensure they go back in correctly. I also try to keep the springs in order with the slippers, but it is not always possible and so far it does not really seem to matter.
The noise can also be caused by air trapped in the system, clogged pump screen and/or contaminated burned fluid.
Old 10-10-2012, 03:08 PM   #10
Jbeas50's Avatar
Yea mine turns fine but just makes the noise when I turn the noise is louder then my car
07:13 PM
