Fuel pump issues! Can anyone help? - Mustang Evolution
Old 04-11-2008, 05:41 PM   #1
Region: Delaware
Exclamation Fuel pump issues! Can anyone help?
So I am having problems with my fuel pump. I have changed the fuel pump relay but for some reason when I shut the car off the fuel pump stays on; continuously clogging the choke and draining my battery! So I am left with a car that has to have the battery disconnected everytime I stop for longer than 10 minutes. If anyone has any type of advice on what the issue may be please, please, please reply to this post! The car I have is a 1986 5.0 GT hatchback!
Stangbaby302 is offline   Reply With Quote
Old 04-11-2008, 06:44 PM   #2
Kiljosh's Avatar
Re: Fuel pump issues! Can anyone help?
Sounds to me like you wired the relay in wrong. Unless this was happeneing before you changed it Im betting it's a bad relay or bad wiring.
Old 04-12-2008, 06:25 AM   #3
Region: Delaware
well i dont think the wiring got messed up becuase the relay is a simple plug in peice and yes this was happenin before i changed the relay... im not quite sure why the car is doing it but its pretty annoying to have to pop the hood everytime i shut the damn thing off thanx for the help though.... if you think of anything else man im all ears
Old 04-12-2008, 08:28 AM   #4
silverstangboy's Avatar
your probably using the wrong relay, same thing happened to me, parts counters cannot seem to get the right piece for a late92-93 harness, finally picked up the right part from ford. no more problems.
BTW, you running a carb?
93 mustang notch
~450hp 331 stroker - Sold
Old 04-12-2008, 05:54 PM   #5
Region: Delaware
Sadly no I have the year after they discontinued carbs.... sucks but shes quick! shes all stock and runs a good 12.5 1/4 mile... so no complaints yet... and yea your probably right bout the relay i bought this one from a local parts store... guess ill try a ford motorcraft peice and pray it fixes the damn problem...
Old 04-13-2008, 01:44 AM   #6
stang_gang's Avatar
put a toggle switch in their so you dont have to un plug the battery untill you locate the problem.
Mustangs are not anobsession they are a way of LIFE!!!
stang_gang is offline   Reply With Quote
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 04:22 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 02:45 PM
engine issues... no codes... fuel pump video added jimmy_beaner 1996-2004 Mustang GT 99 05-02-2009 12:56 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-12-2005 12:04 AM
fuel tank and radiator issues... mustangmare Pre-2005 V6 Mustang 1 11-01-2004 08:09 PM
01:13 PM
