Ebrake button fix? - Mustang Evolution
Old 10-11-2012, 11:07 AM   #1
Blown347's Avatar
Ebrake button fix?
Okay so my ebrake button has rattled forever. Was just wondering f one of you knew a cheap way to fix it instead of buying a new lever?
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 10-11-2012, 06:25 PM   #2
Filibuster
Mine does the same s**t!
Unfortunately with my exhaust setup rattling my entire car like a goddamn harley. I don't think certain rattles are goin away without good fixins!
I would like to see if someone knows an easy fix as well.
XXSTEVEO66 is offline   Reply With Quote
Old 10-11-2012, 06:30 PM   #3
bubble gum?
idk....
Old 10-11-2012, 07:19 PM   #4
foxbox's Avatar
Its 90 dollars for an entire ford ebrake assembly @ cj pony parts. But its just a worn out spring that it suppose to keep that button in position. If you take it apart, you should be able to pick up that spring at any hardware store.
foxbox is offline   Reply With Quote
Old 10-11-2012, 09:41 PM   #5
Blown347's Avatar
I read earlier in another forum as well that if you pull the brake all the way up so the button is pushed out you can wrap a thin piece of electrical tape around the base and it will stop. Im going to try it, but if it doesn't work, I was thinking the same thing, just finding a spring at a hardware store.
01:07 PM
