Hood and tranny question - Mustang Evolution
Old 10-12-2012, 07:53 PM   #1
Phantom87's Avatar
Will a 1983 gt hood fit a 1987 gt and will a 1978 tranny bolt right up in a 87
Phantom87 is offline   Reply With Quote
Old 10-12-2012, 07:55 PM   #2
deadsp0t's Avatar
Not sure about trans but the hoods won't swap.
That's unimpressive
Old 10-13-2012, 02:04 PM   #3
The trans will probably bolt up, but they are so weak I wouldn't bother with it. If it is a manual it is only a 4 speed too, so you won't have OD and it will kill your gas mileage.
Old 10-18-2012, 11:04 AM   #4
Phantom87's Avatar
It's aod.
Old 10-18-2012, 11:50 AM   #5
Originally Posted by Phantom87 View Post
It's aod.
Not out of a 78 it isn't.
If it came off of a 302/5.0 it will bolt up.
Old 10-19-2012, 11:01 AM   #6
Phantom87's Avatar
I meant automatic
---------- Post added at 09:01 AM ---------- Previous post was at 08:58 AM ----------
It's a c6 that was on a small block so I think I have to get my driveshaft shortened
Old 10-19-2012, 02:35 PM   #7
I meant automatic
IF, it is a C6 then it will be strong enough, but you will lose the overdrive gear and your gas mileage will suffer considerably.
If it happens to be the C4 instead, then it is much weaker, but can be built to reliably handle a lot of power, but you will still lose the overdrive gear.
Old 10-22-2012, 07:56 AM   #8
Phantom87's Avatar
It is the c6. It's not a daily driver at all so I don't mind the mileage issue.
04:28 AM
