Cleaning - Mustang Evolution
Old 10-14-2012, 09:25 AM   #1
04machazblue's Avatar
Cleaning
Well I got the motor out heads off and all accessories timing cover and cam out and I am gonna clean the block what should I use it's all grimy but no blow by and the Cylinder walls look great rings also
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 10-14-2012, 10:36 AM   #2
89 coupe's Avatar
I really like this stuff, works well.
89 coupe is offline   Reply With Quote
Old 10-14-2012, 10:58 AM   #3
rwsmith3623's Avatar
Are you planning on using water?
rwsmith3623 is offline   Reply With Quote
Old 10-14-2012, 11:44 AM   #4
I would like to avoid using water
Old 10-14-2012, 11:52 PM   #5
Won't hurt it. Use HOT water and soap to loosen and dissolve the grunge, rinse with hot water and blow dry.
Grab a set of block cleaning brushes and pay particular attention to all of the oil passages to get the crud out of them.
Old 10-15-2012, 09:58 AM   #6
How much would it cost to get the block honed at a machine shop and cleaned
Old 10-15-2012, 10:34 AM   #7
91notchback's Avatar
Excuse me for butting in to your thread. What is the best way to clean a running engine? I've heard low pressure water but I dont want to get moisture in anything that will harm it.
91notchback is offline   Reply With Quote
Old 10-15-2012, 10:41 AM   #8
No problem dude and I am trying to figure this out as well lol
Old 10-15-2012, 10:48 AM   #9
Is your motor apart? If so, I don't see what it would hurt to use low pressure water. Especially if you are going to do a full honing.
Old 10-15-2012, 02:47 PM   #10
I don't really know in your area. Last time I had one done it was around $8-$12 a hole for bore/hone and cleaning was around $25. I imagine prices have risen considerably since then.
Really low pressure hot water (like a gentle rain) and a good engine degreaser. You want to take steps to ensure water does not get into any electrical & ignition components. It is best to cover them with plastic bags and hand clean them later.
cleaning throttle body todd mulder 2005-2010 Mustang GT 22 09-01-2012 06:01 PM
engine bay cleaning Horseplay Mustang Paint, Appearance & Detailing 10 01-27-2012 09:02 AM
Cleaning heads Cm644rodrigues 1979-1995 Mustang GT 3 11-05-2011 11:37 AM
Quick Cleaning skyline247 Mustang Paint, Appearance & Detailing 8 07-09-2011 06:39 AM
Throttle body cleaning Mustanglife Pre-2005 V6 Mustang 10 07-04-2011 01:32 PM
09:39 AM
