brakes - Mustang Evolution
Old 10-15-2012, 08:37 AM   #1
brakes
On 94-95 GT's is there more braking force in the front or rear? I'm thinking front or maybe even 50/50 but I may be wrong...
Georgia331 is offline   Reply With Quote
Old 10-15-2012, 03:27 PM   #2
The bias is always towards the front brakes, otherwise the back brakes could lock and cause an uncontrollable skid.
The exact bias depends on the brakes used, weight of the car, etc., etc.. The proportions are different for disk and drum brakes, which is why when converting an older Mustang to rear disk brakes you need to change the master cylinder and proportioning valve.
Old 10-16-2012, 07:38 AM   #3
Ok cool. Reason I'm asking is...to save some money I was thinking of keeping the rear rotors stock and going slotted up front with hawk pads all the way around
Old 10-16-2012, 10:18 AM   #4
You're Welcome & Good Luck with your project.
That should not have any effect on the proportioning.
Old 10-16-2012, 10:45 AM   #5
slotted/drilled wont really do anything for stopping with OEM style pads, but they will look different. If they are not coated they will rust like crazy FYI (you can paint them with high temp engine paint (every inch of them if you wish) after you remove any oil from them from the factory.
Old 10-16-2012, 03:22 PM   #6
Hawk makes slotted and UV coated replacement rotors for 190 a pair so I was going to turn the rears and put these on the front. I was also going to run Hawk pads (street/track pads) on all four corners.
Old 10-16-2012, 04:33 PM   #7
Yeah the benifits of a drilled/slotted rotor are just cooling. They are great for auto x where a lot of hard breaking is going on.
Old 10-17-2012, 06:33 AM   #8
That's what I bought the car for
09:12 PM
