explorer gt40 - Mustang Evolution
Old 10-15-2012, 01:59 PM   #1
thomas91gt's Avatar
explorer gt40
What size is the throttle body port on the intake? trying to see if i would really benefit any by using anything bigger than a 65mm
thomas91gt is offline   Reply With Quote
Old 10-16-2012, 09:45 AM   #2
thomas91gt's Avatar
Ok does anyone have an opinion on best cam to use with this intake?
Or rpm range of it?
Old 10-16-2012, 12:39 PM   #3
93slowstang's Avatar
Your not going to benefit much if any by using a tb larger than 65mm. A few people run the e303 or b303 cam and love it but I would go to camquest and see what can specs it gives. You should be able to pick one similar to the specs it gives.
Old 10-16-2012, 02:29 PM   #4
thomas91gt's Avatar
Yea the opening is 68mm so ill prolly go ahead and go 70 ill get on camquest and check that out tho thanks
Old 10-16-2012, 07:50 PM   #5
thomas91gt's Avatar
Has anyone ever ported one of these??
Old 10-16-2012, 08:04 PM   #6
i havent personally done that intake, but i have done others. i usually gasket match and smooth the casting flash.
what you want to do is put the gasket on the intake. put a few bolts in so the intake is aligned. then use a scribe or scratching tool to trace the inside of the gasket. then using a dremal tool open it up to the lines. then use a finer bit or flapper etc on the inside and smooth put all the casting flash. also radius any sharp corners and knock down any high spots.
summit racing and jegs sell kits to use with dremals and die grinders that will have everything you need to do it really nice. you can also search youtube and find some good how to videos.
Old 10-16-2012, 09:51 PM   #7
thomas91gt's Avatar
Yea I've watched some you tube on it doesn't look very hard I work in metal fab I think I'm gonna try it
Old 10-16-2012, 09:56 PM   #8
Cool. Good luck.
Btw if its the tubular intake, I don't think you can take go very far with it. But you can definitely still smooth the casting flash.
Also check in the useful info sticky thread. Maybe under tmoss ?
Old 10-16-2012, 10:17 PM   #9
thomas91gt's Avatar
Yea explorer intake I read that he mostly talks about the stock intake
Old 11-16-2012, 02:52 PM   #10
thomas91gt's Avatar
Can i use the same intake bolts as the stock intake, when installing a explorer gt40?
Old 11-16-2012, 03:02 PM   #11
Yes
Old 11-19-2012, 07:03 PM   #12
thomas91gt's Avatar
What exactly is the purpose of the pintle caps on the bottom of the injectors? I did gt40 swap an now its missing like crazy i noticed some of them were cracked didnt replace i plan on it just none of the parts stires had them instock plan on just gettin new injectors
Old 11-20-2012, 05:54 AM   #13
5.slow's Avatar
Region: Delaware
I have the explorer intake also. Mine was fully ported, upper and lower. I'll see if I have any pics I can post.
5.slow is offline   Reply With Quote
11:42 PM
