Egr spacer - Mustang Evolution
Old 10-17-2012, 07:34 AM   #1
91notchback's Avatar
Egr spacer
So I deleted my egr. Are the two hoses on top of the spacer some kind of coolant? If so, what do they cool? Do I need them if my egr isn't hooked up?
91notchback is offline   Reply With Quote
Old 10-17-2012, 11:31 AM   #2
Did you have your car tuned? You don't really need to do anything. Some people block them off thought.
JayKranz is offline   Reply With Quote
Old 10-17-2012, 11:45 AM   #3
No. I got the mil eliminator. Gonna hold off on a tune until I get a fresh short block and top end kit after the first of the year. If its not affecting anything, I'll just wait until teardown. Thanks man!
Old 10-17-2012, 12:07 PM   #4
Just put rubber caps on them then.
Old 10-17-2012, 03:09 PM   #5
5.slow's Avatar
Region: Delaware
How absolutely necessary is the tune if you eliminate the egr?
5.slow is offline   Reply With Quote
Old 10-17-2012, 03:37 PM   #6
Rubber caps on the spacer and use pipe plugs or fittings to plug the outlets on the tube and intake. Trying to use vacuum caps there is a mistake. Someone doing just that is how I bought my car as cheaply as I did. They were leaking and they thought it had blown a head gasket.
Old 10-17-2012, 03:39 PM   #7
It's not necessary. You can use the CEL Eliminator to turn off the light.
Old 10-17-2012, 05:54 PM   #8
5.slow's Avatar
Region: Delaware
Does the tune simply turn the light out or does it help the computer run properly without it installed? Mine is eliminated as described above, I'm just curious because I don't have a tune.
Old 10-17-2012, 06:12 PM   #9
Both. When the computer thinks the egr ain't there, it will go into a closed loop. It will be trying to compensate for a problem, messing with the a/f ratio.
Old 10-17-2012, 06:15 PM   #10
It just eliminates/disables the EGR CEL. The ECU will tune itself to take advantage of the cooler air flow through the intake and changes in the exhaust gasses as sampled by the O2 sensors.
Old 10-18-2012, 07:30 PM   #11
67mustang97's Avatar
Region: Vermont
Why would you eliminate the EGR? Do you gain power?
Old 10-18-2012, 07:52 PM   #12
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
You are basically circulating hot coolant in there causing the temps to rise in the air going in. By eliminating the egr you are getting cooler air to enter the intake. Cooler air = more power
Granted it won't be that noticeable of a difference in power if any at all.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-18-2012, 10:34 PM   #13
93slowstang's Avatar
I think you're getting the coolant line in the spacer and egr a tad mixed up. Lol
The egr isn't open under acceleration, only while cruising and idle. There isn't any proven data of gained hp but it does clean up the engine bay.
Old 10-19-2012, 03:10 AM   #14
Pete Jones
Doh! Yup, was reading coolant and line and spacer, my bad lol
90 LX hatchback
89 LX Notchback
« Cam? | 87 GT »
04:44 AM
