rim grinding on inner a-arm help! - Mustang Evolution
Old 10-19-2012, 07:16 PM   #1
cgarray17's Avatar
Like it says when i turn all the way to the left the driver front tire inner rim and tire grind on the arm. Its been doing it since i got the car but is finally bug me enough to try and figure out what might cause it and if i can adjust something to stop it? It does not do it when turned all the way to the right only left. Car is a 94 gt
Thanks
94 GT Convertible
Current- Stock long block 118k, MAC CAI, 75mm Pro M MAF, PP 70mm TB,BBK shorties,BBK O/R H, Magnaflow catback, KING cobra clutch, 3.73 Gears
Soon to be Vortech blown with a built 306 Numbers and times to follow!!!
cgarray17 is offline   Reply With Quote
Old 10-19-2012, 07:22 PM   #2
it maybe cause the rim is a hair big. you can pick up steering rack limiters or change the rims.
Old 10-20-2012, 01:21 PM   #3
Mike90's Avatar
As said above, my rims are 17x9's in the front and rub on the steeda sway bar.
I have the rack limiters wich were purchased at my friendly local ford dealer.
haven't put them in yet been lazy. You could also use a small wheel spacer, I
did this on my 90lx with 17x9 04' cobra wheels up front...
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 10-20-2012, 03:52 PM   #4
cgarray17's Avatar
Ok thanks i was going to do a New K member and tubular a arms with my new motor in the spring so i hope that might fix it
94 GT Convertible
12:34 PM
