Wiring in a relay to toggle switch - Mustang Evolution
Old 10-20-2012, 11:48 AM   #1
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Ok so here's what I have:
Toggle switch with wire from battery going to it
4 prong relay
85 prong gets 12v from toggle switch
86 prong is ground
87 is 12v to the fan
30 prong is 12v from the battery
Do I have this correct?
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-21-2012, 02:11 AM   #2
4 prong relay
86 prong is ground
Here's a diagram.
Name:	Single Speed Fan Toggle Switch Wiring.jpg
Old 10-21-2012, 07:03 AM   #3
Pete Jones
Originally Posted by Trojan Horse
Here's a diagram.
So I have a positive ground? Sorry, not very wiring savvy. I was hit going to leave the fan grounded the eh I have it and ground the relay to the battery, but from the looks of it, I may need to so like this diagram suggests.
90 LX hatchback
89 LX Notchback
Old 10-21-2012, 08:49 AM   #4
89 coupe's Avatar
Follow the diagram it's pretty straight forward instruction.
89 coupe is offline   Reply With Quote
Old 10-21-2012, 11:00 AM   #5
Jar72's Avatar
Which kit do you have for it I installed one in mine a couple weeks ago it works great. If u want I can post pics of all my connections and where I mounted everything.
JMF
Jar72 is offline   Reply With Quote
Old 10-21-2012, 12:10 PM   #6
Pete Jones
I followed it but didn't work. I found a different one yesterday and it worked.
No kit, just a toggle switch with a relay wired into so I don't burn up the switch.
90 LX hatchback
89 LX Notchback
Old 10-21-2012, 12:50 PM   #7
No that's not positive ground.
Positive ground is where the positive post of the battery is connected to the engine/frame and the negative side is used to power all of the components.
The diagram is just suggestive, you can get your power or grounds from wherever you have a place to get them as long as the power attaching point will provide sufficient amperage to run the fan.
Old 10-21-2012, 12:51 PM   #8
Show me what you found and I can tell you why.
Old 10-21-2012, 02:41 PM   #9
Pete Jones
Here's what I found TH, drew a little picture for ya
85-12v from toggle switch
86-straight to ground
87-12v out to fan
30-12v from battery
90 LX hatchback
89 LX Notchback
Old 10-21-2012, 03:45 PM   #10
87-12v out to fan
30-12v from battery
That's pretty much exactly the way my diagram showed it too.
Old 10-21-2012, 03:54 PM   #11
Pete Jones
It's been working flawlessly all day and the switch never got the slightest bit hot, def a lot happier with the piece of mind. I even tested the the empty slots in my fuse panel again but no power was getting to them with the key on or off.
90 LX hatchback
89 LX Notchback
Old 10-21-2012, 06:21 PM   #12
The switch shouldn't get hot at all in this configuration. All you are pulling through it is the small amount of power it takes to activate the relay coil.
Old 10-22-2012, 04:47 AM   #13
Pete Jones
Yea, what I meant was compared to before when I just had it wired to the switch no relay.
I think when I followed your diagram before I didn't ground the relay or fan. I think I took the ground from the relay and plugged it into the fan so I ended up grounding the relay and fan seperate to get it to work. I think that was my problem.
90 LX hatchback
89 LX Notchback
Old 10-22-2012, 10:04 AM   #14
I think when I followed your diagram before I didn't ground the relay or fan. I think I took the ground from the relay and plugged it into the fan so I ended up grounding the relay and fan separate to get it to work. I think that was my problem.
Just explaining a bit as to why the switch should no longer heat up.
Did not intend to criticize your post.
That would keep it from working.
Old 10-22-2012, 10:15 AM   #15
Pete Jones
No offense taken i knew what ya meant
90 LX hatchback
89 LX Notchback
04:29 AM
