What "should" it cost to re-ring and assemble my engine? - Mustang Evolution
Old 10-21-2012, 03:15 PM   #1
I have everything but gaskets. Who should it cost to have a shop pull my motor(go through it), re assemble without machine work? Like I said I have everything except a new ignition.
---------- Post added at 04:15 PM ---------- Previous post was at 04:14 PM ----------
What not who, dang auto correct!
JayKranz is offline   Reply With Quote
Old 10-21-2012, 04:03 PM   #2
I may not need it. My car is running rich andI have some black smoke due to that. Just nervous about pushing 500-600hp if the rings are bad
Old 10-21-2012, 05:25 PM   #3
Gil_T2's Avatar
It is the same as rebuilding the motor. and depends on the mileage and cyc ware.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 10-21-2012, 05:26 PM   #4
Okay, so they don't really base it on level of difficulty then.
Old 10-21-2012, 05:54 PM   #5
Gil_T2's Avatar
If you are talking Book Price, Every car has different labor hour quotes , depends on car, options, make , model etc. But when it comes to the motor there isn't a re-ring price, it all comes under total rebuild.
Old 10-21-2012, 06:17 PM   #6
The cost is basically going to be the same as a rebuild minus the machining costs of course.
I wouldn't be too concerned about the black smoke from being to rich, unless you drive it like that to much, which will eventually damage the rings and cylinder bore. What you want to look for in a boosted engine is the blow by. When it starts pushing the dipstick up out of the tube or chugging like a choo choo train when you have the oil cap off, then you probably need some new rings.
Old 10-21-2012, 06:18 PM   #7
If you are worried about your rings do another compression test.
Old 10-21-2012, 06:32 PM   #8
My compression is fine. I have loud valve train, fuel smells and some black smoke. I'm guessing this would all be attributed to the ripens that's about to go int the garbage anyway, right?
Also, TH, Dream DSS Racing has my short block with the heads I just bought in a dyno video on their website. It came out at 458HP without the turbo. They also claim with the DSS girdle I have that the block can handle up to 650HP. Just fyi
---------- Post added at 07:32 PM ---------- Previous post was at 07:31 PM ----------
How does spell check get "ripens" from "top end"? Annoying!
Old 10-21-2012, 06:34 PM   #9
you sent it in? or they have the same setup on a video?
i have heard that it will take that much with the girdle kit. thats the theory trojan is gonna test, and you.lol
Old 10-21-2012, 06:34 PM   #10
That's good to hear. That's the main reason I bought their main support system, the girdle and the windage tray. Supposedly all that thick aluminum is very good at canceling out harmonic rotating assembly vibrations.
Oh yeah, what's a "ripens"?
Old 10-21-2012, 06:34 PM   #11
ripens?
Old 10-21-2012, 06:36 PM   #12
They have a video I my exact set up buy not my actual engine.
@TH I have no idea
Old 10-21-2012, 06:45 PM   #13
@TH I have no idea
Maybe the auto correct was talking about maters? They ripens on the vine don't they?
Old 10-21-2012, 06:51 PM   #14
Haha right!
Old 10-21-2012, 06:55 PM   #15
Lorraine's driver
ab_mach1's Avatar
That's the oddest auto-correction I've seen. Funny
Instagram: @ab_mach1
Old 10-21-2012, 06:57 PM   #16
That's what I was thinking too Az.
Old 10-21-2012, 07:06 PM   #17
Yes sadly, your auto correct gremlin may be dumber than most.
Old 10-21-2012, 07:08 PM   #18
Okay, so I'll roll the dice on my short block. I'm going to pay a local shop about$1000 to throw my heads and stuff on. Not having a garage blows!
Old 10-21-2012, 07:36 PM   #19
Which ignition should I get? MSD 6AL? or the BTM?
Old 10-21-2012, 07:38 PM   #20
we'll see what trojan says, but i think the btm will be useless. because the tuner will be able to set the timing functions built into the tune. so no reason to pay the extra money for the btm.
Old 10-21-2012, 07:39 PM   #21
That's what I was thinking too.
Old 10-21-2012, 07:51 PM   #22
I forget, what are you tuning with, chip, PMS or other?
Most likely the plain old 6AL will work and don't forget a good coil to go with it.
I got the Digital 6 because I ran across one for a decent price, but the extra functions probably won't be needed with my PMS.
Old 10-21-2012, 07:55 PM   #23
I have a custom tuned sct chip,
---------- Post added at 08:55 PM ---------- Previous post was at 08:54 PM ----------
Also, do I need a different PMAS maf sensor if I go from 42 to 60lb injectors?
Old 10-21-2012, 08:00 PM   #24
Yes, unless your tuner can re-program it too or program around it in the chip?
I'd sell it and get the ABACO MAF, You can fine tune that one yourself on your laptop or desktop PC.
Old 10-21-2012, 08:05 PM   #25
i say if they can reprogram it then let them. he will already be paying for the tune so i dont really think it would cost extra. and with his setup he wont be changin the maf and injectors without retuning. in most cases i would say go with the abaco, but i just dont see it worth it here, unless he plans on tuning himself in the future. with that said they are badd a$$ though.
Old 10-21-2012, 08:07 PM   #26
Yeah, I'm not going to tune myself. Someday when I have a garage I'll be more hands on but for now I'll leave it to the shops.
Old 10-21-2012, 08:08 PM   #27
Lorraine's driver
ab_mach1's Avatar
That's a cool MAF! By re-program, is that the same as re-calibrate?
Old 10-21-2012, 08:29 PM   #28
To most people it wouldn't be, but since it provides the ability to further refine the air/fuel curve inside the basic program, I would or rather did do it.
You don't need a shop to tune it, just a PC.
Yes, plus you can fine tune the MAF air/fuel curve inside the base program for your chosen injector size for even better results. The issue there though, is that most people won't want to take the time to learn how to do that.
05:42 AM
